Dogbones problem?
Old Feb 4, 2005 | 12:03 PM
conv90's Avatar
conv90
Default Dogbones problem?
It's longtime that im trying to cure an handling problem...
The rear seem disconnected from the car
I feel like if the rear is in the water and im drivig a boat!
It seem I'm runnig with 2 rear tire FLAT!
I cheched all
alignment
tie rods
u joints
Hub bearings
All is ok
yesterday I looked at the driver side "dogbones"...
the upper one is good attached to trailing arm bracket,but the rear eye of the rod is nor good attached to the knukle..
This rear bolt is fully inserted in the knuckleand in the rear eye of the dogbone....but the NUT (in the inner side) is 1 full inch far from the dogbone eye!
Could be this the problem?
Iìm trying to torque down this nut but it's really hard and Im not able to block the head bolt.
What's (or are) the problem(s) associated to a not properly installed dogbone?
-Beppe-
Old Feb 4, 2005 | 12:09 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
are you able to post a picture of what you are looking at?
Old Feb 4, 2005 | 01:27 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
once when i went auto-x'ing, i forgot to tighten the toe rod securely and it worked loose a little. it got so squirrely in the rear, spectators said they could see my rear tires change camber, which prompted me to check the toe rod. a loose ( 1") dogbone could cause you problems.
check the bushings in the dogbones and your camber rods.
Old Feb 4, 2005 | 06:12 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Unless you mix up the short and long dogbones there is no way to install them wrong. Sounds like the bushings are totally shot. If you decide to go poly, do the whole car, front & rear for max improvement.
Old Feb 4, 2005 | 07:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
These pics are in order and show what happens when you break your dogbones(only on the drivers side this happened)
Old Feb 4, 2005 | 10:58 PM
vms4evr's Avatar
vms4evr
Ouch! That doesn't look good!
A mechanic that was working on my rear diff a little while ago mentioned that he thought the one of the dog bones was not in that good a shape. They aren't physically bent or anything. The bushing do look compressed and dry rotting. He told me to replace all of them.
As I understand it GM doesn't sell new bushings for those and want you to buy the whole peice. So they have a poly bushing kit for these? I imagine I would have to have the old ones pressed out and the new ones pressed in at a machine shop. They don't look like something a bench vise would do well with. Sound about right?
Old Feb 5, 2005 | 01:16 AM
Sleazy Rider
just be careful when you pop out the old bushing. these things are under compression and when they pop loose, its like being shot out of a cannon, and they're rubber so they bounce.
Old Feb 5, 2005 | 04:22 PM
vms4evr's Avatar
vms4evr
Thanks. I'll go find the poly bushings and just ask a machine shop to do the replacement. They can duck when the bushings pop
Old Feb 5, 2005 | 04:59 PM
rodj's Avatar
rodj
I just drilled a few holes in the rubber with a 1/8 drill so I break the steel bush loose , then pushed the rubber out with a screwdriver.My new VBP poly bushes went in by hand (well lubed) and I only had to use the vise for the final 1/4 inch.Easy
Your bushes must be well shot.Both my bottom dog bones were bent down and out as a result of being chained down in a past life , had the original bushes and still drove fine.Can feel difference now but never felt "loose "before.If I knew how to post a pic on here could show how far away from stock you can get and still drive OK.
To Dogbones problem?
