Torque numbers front spring...
Old Feb 4, 2005 | 01:30 PM
BlackRocket's Avatar
BlackRocket
Default Torque numbers front spring...
I just installed a Mid-America lowering kit on the front spring. I cut the brackets about 1/2" and had to place the aluminum spacers under the bracket to prevent running out of thread. When tightening the bolts, the brackets are about 1/4" from hitting the crossmember when snug. It takes about 80' lbs to cinch-up the brackets up to the frame. When tight the stock rubber spring pads are smashed a bit. Is this too tight or just right. I can see about 1/4" of the rubber pad pressing out on the sides. Obviously the spring needs to be tight due to the extreme forces it's subjected to, but not sure if this is too tight???
Any input or experience with this would be appreciated...
