DRM CoilOver Suspension Kit
Old Feb 4, 2005 | 08:22 PM
cprgmr's Avatar
cprgmr
Default DRM CoilOver Suspension Kit
Anyone here running the DRM Coilovers on a C4?
DRM CoilOvers
Looking for feedback, pros and cons. TIA!
Old Feb 4, 2005 | 09:13 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
not me, but i'd also be curious to hear from those who are, especially with respect to launches at the drag strip...
Old Feb 4, 2005 | 09:15 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Might want to check in the auto-X/road racing section too.
Old Feb 4, 2005 | 09:32 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Where's the reinforcements for the shock towers? I definitely wouldn't trust them carrying all that weight they weren't designed for.
Old Feb 4, 2005 | 09:54 PM
Mo_Bandy's Avatar
Mo_Bandy
Running QA1's here but DRM's are good a little more pricey....
The older C4's you should consider beefing up the front towers a bit. I have over 50,000 miles on miine, no isssues to speak of and 2 cross US drives....
You can visit my website in my signature, I show what I have done...
It handles tremendously better! Launches GREAT!
I'm not sure if the DRM setup is adjustable...
Mo
Old Feb 4, 2005 | 09:58 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I have them and like them alot.
What type of pros and cons are looking for
mfg ??
Old Feb 5, 2005 | 03:06 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Show me one from a 88+ that has blown it out. Not a friend of a friend.
Got them, race on them and daily drive on them. Best suspension mod you can make.
Old Feb 5, 2005 | 10:49 AM
cprgmr's Avatar
cprgmr
Thanks for the info guys. I don't autocross the car - it only sees weekend driving and the strip. I was going to lower the car a bit and was doing some research on what has to be done for the front and rear.
The rear is a piece of cake, but you have to take the front transverse spring out and if I'm going to do that, I might as well just get coilovers and have multiple options for ride height adjustibility.
For those of you who have them, did you install yourself? If so, was it a PITA? Any gotchas? Thanks!
Old Feb 5, 2005 | 05:39 PM
Mo_Bandy's Avatar
Mo_Bandy
CPRGMR,
Visit my site I go into it... Wheterh you chosse QA1's or whoever you would be pretty much dealing with the same issues...
I had to move the front sway bar forward, you can get mounts for the sway bat to the lower A fram otherwise when you drop it the swaybar will be hiting the spring.
The rears I had to move the top mounting holes forwar about 3/4 of an inch as you drop the car the clearance between the half-shaft and the coilover get very close...
If you take our time, you'll be fine it's not THAT bad...
If you have questions feel free to email or PM me...
I found going lower than say 25 3/4 in the front and 26 1/2 is about as low as you would want to think about going... I'm at 26 1/2 and 27 1/2 with a full tank and I clear about every speed bump there is... (measured from the ground to the middle if the fenderwell...
The front spring removal is the worst of it all...
Mo
Old Feb 5, 2005 | 06:23 PM
Coupe89's Avatar
Coupe89
Old Feb 5, 2005 | 06:43 PM
cprgmr's Avatar
cprgmr
Originally Posted by Mo_Bandy
CPRGMR,
Mo
Thanks Mo! I can see what you're talking about based on your pics.
The setup I'm looking at from DRM utilizes the existing FX3 shocks. I wonder if I would have the same clearance issues with the coilovers staying with the Bilsteins? I couldn't find any further info on the DRM website...
Old Feb 5, 2005 | 07:02 PM
LD85's Avatar
LD85
So you got me hooked,
I checked out the front shock tower today on my 85 and I cant imagine how I could fit a coil over a shock in the front.
I can see where I can move the sway bar forward (per Mo Bandy) but I cant see how a shock will fit into the small channel where the shock goes, am I just paranoid? Do I have to cut some of this away?
Old Feb 5, 2005 | 07:14 PM
Jeffvette's Avatar
Jeffvette
Just call Randy at DRM and talk to him. He will be more than happy to assist you.
As far as clearance, you need to spread the sides a little bit to clear. It doesn't matter whose shock you use, you still have to make room for the hat and the coil. I believe this pic is from Coupe89. I'll be taking pics of my setup when I clean everything for spring.
Old Feb 5, 2005 | 07:47 PM
dan6712cc's Avatar
dan6712cc
Why did GM go with leaf springs on our Vettes instead of a 4 wheel independant suspension? Are leaf springs better for the track, and coil overs better for daily driving?
Old Feb 5, 2005 | 08:55 PM
Bruce's Avatar
Bruce
eh? what ya talkin about? our vette is a 4 wheel independent suspension.
Bruce
Old Feb 5, 2005 | 09:19 PM
Coupe89's Avatar
Coupe89
My .25
I moved the tower about 1/8 of an inch if that.
I have more pic floating around on my website (I need to find them)
Its cheeper to go with the leaf spring. There is nothing wrong with them. A lot of people have road race and auto-x with them.
Coil-overs are just over kill. I got mine used and cheep. If I had to do it over again I would use coil-over setup by QA1.
EDIT:
Few more pics.
http://www.ong-inc.com/car/vett/DSC03153.jpg
http://www.ong-inc.com/car/vett/DSC03154.jpg
http://www.ong-inc.com/car/vett/DSC03155.jpg
http://www.ong-inc.com/car/vett/DSC03156.jpg
Old Feb 6, 2005 | 01:37 AM
Mo_Bandy's Avatar
Mo_Bandy
I used a large wrench and bent out the top outside ends to make room for the hat and springs I didn't have to really move it too much... QA1's are like 2.5 inches which is pretty much standard.
I would think you can still stay with the FX shocks , what most ppl do is cut a groove in the bottom of the shock and slide the threaded piece over the bottom and a circlip holds it in place. Like Jeffvette's (?)
Jeff did you move your swaybar forward? I like your swaybar to A-frame mounts are those from DRM? Nice polish job...
Mo
To DRM CoilOver Suspension Kit
Old Feb 6, 2005 | 01:48 PM
Angelsword's Avatar
Angelsword
I’ve been running the DRM system now for over two years. The difference in handling is unbelievable even for a novice racer like me.
My son and I made the change in our garage with a good set of hand tools, floor jack, good jack stands, and some help from a local Corvette specialty shop for pushing the new bushings in. It was not an easy job, don’t be in a hurry, measure carefully, you do have to relocate some mounting points and components, and remember it’s a labor of love. And when you don’t know…call DRM. They were very helpful. When you’re done, take it to a good alignment shop, someone who knows Corvettes.
There is such a thing as “too low”…particularly for daily driving here in North Texas. It’s easily adjustable, takes some time to get it just right.
The ride stiffness is more a function of the shocks than the spring rates. I have considered getting a softer set of shocks…but, hey, I’m not that old yet.
And, no it’s not too loud!
Old Feb 6, 2005 | 06:03 PM
zelement's Avatar
zelement
If you would to blind fold someone in a coilver equipped C4 then put the leaf springs back in the same C4 and ask the same person to go for a second ride, I am willing to bet no one would believe they were in the same car.
C4s stock handle great on perfect flat surfaces but how often do we drive on that? I wish every C4 owner could feel the difference with coilovers. The handling is seriously night and day, especially on not so perfect surfaces.
Old Feb 6, 2005 | 06:24 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I run the chamber brace and trailing arms,urthain kit and it raised the D44 rear about 3 inches.
