Max PSI on V2SQ?
Old Feb 5, 2005 | 11:16 AM
BAM92's Avatar
BAM92
Default Max PSI on V2SQ?
Also what is max PSI you can get out of a T trim? These, of course, is without over spinning the blower and safely.
Old Feb 5, 2005 | 01:57 PM
LPDesRoche's Avatar
LPDesRoche
Do you want to know the max for a T trim or for a V2-SQ? As far as I know there is not a SQ version of the T trim.
Straight from the Vortech site:
VORTECH V-1 T-TRIM SUPERCHARGER
The supercharger of choice for street/strip vehicles with modified engines
Straight cut spur gear
Fits engines up to 825 horsepower
Maximum airflow: 1,200 CFM *
Maximum boost pressure: 26 PSI *
Maximum impeller speed: 55,000 RPM
Adiabatic efficiency: 73% **
Available with straight or curved discharge and clockwise or counterclockwise rotation
Lee
Old Feb 5, 2005 | 03:01 PM
BAM92's Avatar
BAM92
Actually both. What is it for the V2-SQ?
Old Feb 5, 2005 | 03:29 PM
LPDesRoche's Avatar
LPDesRoche
Here you go:
VORTECH V-2 SQ SC-TRIM SUPERCHARGER
Helical cut gear profile with SQ technology
Near silent operation
Fits engines up to 680 horsepower
Maximum airflow: 1,000 CFM *
Maximum boost pressure: 20 PSI *
Maximum impeller speed: 53,000 RPM
Adiabatic efficiency: 75% **
Lee
Old Feb 5, 2005 | 03:30 PM
RVY's Avatar
RVY
With a Vortech T trim I'm pulling 17lbs at 5500 engine rpm. Thats 596rwhp. Probably more if I rev it higher but.......
Old Feb 5, 2005 | 03:56 PM
LPDesRoche's Avatar
LPDesRoche
RVY, I would like to talk to you a bit about your setup. I have a T trim as well and would like to talk shop a bit. Shoot me an email at lpdesroche@direcway.com
Lee
Old Feb 5, 2005 | 08:31 PM
Positive Pressure's Avatar
Positive Pressure
ANyone know anything about the Y Models from Vortech? Considering removing a V 2 SQ model and replacing it with the Y...
Old Feb 6, 2005 | 02:03 AM
BAM92's Avatar
BAM92
Thanks Lee for the info and thanks RVY for making me jealous.
To Max PSI on V2SQ?
