I'm trying to replace the rear rotors on my 85 and the rotor on one side is completely stuck to the spindle for some reason!! Anyone have any tips or tricks for gettting them off?? I've tried prying it off, PB Blaster around the studs and center bore, parking brake adjustment and nothing...any ideas??
My method of loosening rotors has never failed me.
I loosen each wheel lug nut about one turn, and run the vehicle in the driveway and hit the brakes hard a couple of times -- both forward and backward. Without the clamping pressure of the wheel lug nuts, the rotor breaks loose from the hub.
When I jack the car up and take the wheel off, I can take the rotor off by hand.
I don't like beating the rotor, and ultimately the bearing, with a hammer.
