which one??
Old Feb 6, 2005 | 10:18 AM
6spd's Avatar
6spd
Default which one??
which one do i have dana44 or dana 44 hd ?? i want 4:11 gears but us gear has 4:11's listed for dana44hd i have 3:45 gears now
Old Feb 6, 2005 | 05:57 PM
6spd's Avatar
6spd
anyone??
Old Feb 6, 2005 | 07:21 PM
bogus's Avatar
bogus
I am not sure what a D44HD is, but I am willing to bet that it is the one for the Viper.
Old Feb 6, 2005 | 07:40 PM
6spd's Avatar
6spd
so the vette's only came with 2 rears a 36 and 44. also i read somewhere that to install 4:11's in the 44 you have to machine the case alittle??? for a perfect fit
Old Feb 6, 2005 | 08:01 PM
bogus's Avatar
bogus
I think that is right... for the 4.11s to fit right, the case has to be relieved a bit.
I know the Viper uses a variation on the D44, but it isn't the same.
Old Feb 6, 2005 | 08:03 PM
chriswtx's Avatar
chriswtx
I got my 4.11's from Tom's Diffs. and they installed in my D44 no problem..No machine work required..
Old Feb 6, 2005 | 11:03 PM
SLOWRIDE's Avatar
SLOWRIDE
You should have the dana 44D its the same as the viper. At least thats what my 1996 has got. I have been to a couple of shops that told me same thing. The dana 44D is bigger than the regular dana 44.
Old Feb 6, 2005 | 11:05 PM
6spd's Avatar
6spd
is there anyway i can tell by looking somewere on the car???
Old Feb 6, 2005 | 11:20 PM
bogus's Avatar
bogus
the Dana 44 in the Viper is not the same as the D44 in the Vette.
The design of the bearing carrier is so totally different, as is the casing.
The D44 is an 8.5" ring gear. That is the common thread between the two diffs.
Old Feb 6, 2005 | 11:28 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
The D44 in C4's & Vipers are actually a heavy-duty version with a thicker pinion shaft. I've heard it called a "Super44"...don't know if that's the same as a "D44HD"...you'd have to check with U.S. Gear.
You can either buy a standard 4.11 R&P set and a 4-series carrier...or a 4.11 "thick gear" R&P, which uses the 3-series carrier you already have. Neither option requires machining of the case.
The 4.11 "thick" gear that Tom's Diffs sells is actually a U.S. Gear product.
I am running one as well, and love it. No noise.
Scott
To which one??
