700r4 trouble
Old Feb 6, 2005 | 12:46 PM
lowace 1's Avatar
lowace 1
Default 700r4 trouble
A couple of weeks ago while just cruising my '86 lost 3rd & 4th.I know 700r4s are notorious for going out at about a 100k and thats where I'm at.But after reading some threads I'm wondering if the govenor might be the culprit.Does anyone know how to get the govenor cover off and how hard is it to replace?
Old Feb 6, 2005 | 12:49 PM
Pete K's Avatar
Pete K
Losing the 3/4 clutch pack is the main reason that a 700 r4 wears out. It is a common way to die of old age. You likely need a rebuild. There are better 3/4 clutch packs out there. Many to choose from with different amount of discs, steels and linings.
Old Feb 6, 2005 | 02:47 PM
CFI-EFI's Avatar
CFI-EFI
The governor cover simply prys off. But leave it alone, that's not your problem. They will service the governor when they overhaul your cooked transmission.
RACE ON!!!
Old Feb 6, 2005 | 03:07 PM
ANTI VENOM's Avatar
ANTI VENOM
CFI, you could put a little sugar on it!!!! lol
Old Feb 7, 2005 | 10:00 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
The same thing happened to my '85 last summer. You're looking at a rebuild. Whoever does the job, make sure they use quality parts. This is a job you want done right the first time. Good luck!
To 700r4 trouble
