315`s Question
Old Feb 6, 2005 | 06:22 PM
2blklt4's Avatar
2blklt4
Default 315`s Question
Hi, got a 96 lt4 and presently have 5 spoke chrome ZR1 9.5 wide rims on all four corners.
I`d like to go wider in the rear and install 11`s with 50mm offset with 315`s tires and also lower rear with 1 inch. I also know that even with 50mm offset rims wheels still stick out a little.
Q: Will my wider rims and tires in the back hit the edge of the wheel whale if i lower the car one inch given the fact that they stick out pass the wheel whale?
On a different note i saw a c4 at a car show with 11`s and 315`s in the rear and they were NOT sticking out at all...not even 1mm...the guy said he had coilovers installed and that made the wheel tuck in more.
What can it be done for our c4`s with 11`s and 315`s and 50mm offset in rear in order NOT to stick out al all?
Thanx guys
Old Feb 6, 2005 | 06:37 PM
Mo_Bandy's Avatar
Mo_Bandy
2blklt4
I'm running exactly what your describe, I'm dropped almost 2 inches and I was fine.
So 1 inch would be no issues... I'm at 27 in the front and 28 in the rear with a full tank of gas...
I have 50 mm offsets and they with the wheels alignedfall right att he flare.
You can see them on my website...
Mo
Old Feb 6, 2005 | 07:05 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Note that on jumps and bumpy roads, the stock 285's will rub the inner wheelwell.(ask me how I know)
I have 315's on 11's with the 50mm offset and they hardly stick out at all, maybe 1/16th of an inch.
I don't see how coilovers will make a difference. The half shafts are still teh same length. For teh coilovers to make a difference, the hub and everything else would have to be located more inboard for the wheels to not stick out unless this guy changed the alignment(camber) or had a custom offset on the wheels.
Old Feb 6, 2005 | 08:10 PM
froggy47's Avatar
froggy47
315's on 11's 50mm offset & they rub a little in agressive autox, not a big deal, just a fender liner
These are Kuhmo's vracer v700's, Tire sizes are NOT exact between mfg's. They are close.
They stick out & I added Grand Sport flairs.
Old Feb 6, 2005 | 08:29 PM
Mr Mojo's Avatar
Mr Mojo
This is true, for reference, I have Michelin Pilot Sports.
Old Feb 7, 2005 | 12:22 AM
Mo_Bandy's Avatar
Mo_Bandy
with Mojo, coilovers make no difference... I'm running Goodyears... alot depends on how much camber you hae by lowering it as well the more camber the less they will stick out at the top, I'm running -1 degree...
Mo
Old Feb 7, 2005 | 01:10 AM
aeronautica86's Avatar
aeronautica86
wheel well
Old Feb 7, 2005 | 09:00 PM
pletner's Avatar
pletner
I have 11"x17" all around and it looks great! No problems so far.
Old Feb 7, 2005 | 09:20 PM
rockindaves96's Avatar
rockindaves96
I cant remember how many sets of 315s ive gone threw and never a problem with rubbing or stickin out.. in fact ive been wondering what a set of 335s with flares might look like back there..
Old Feb 7, 2005 | 11:47 PM
Runum's Avatar
Runum
I have been thinking about 315's on 11's for a while. Thanks for the info. It helps me make the decision. Now I need to finish wearing out the tires I do have so I can have a reason to buy new tires again.
Old Feb 8, 2005 | 12:05 AM
DVNCI's Avatar
DVNCI
I'm not sure what the heck a wheel whale is but my 11" Fikse's with 315 BFG drag radials poke a little past the well, but not much.
Not sure what my offset is, sorry.
Do it!
kopbet89c4's Avatar
kopbet89c4
Yeah, would 335s rub?? I have 17x11 ZR-1 rims
Old Feb 8, 2005 | 12:11 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I narrowed my rear to fit the 315's with 17x11's with the 50 mm offset. I can send photos and guidelines. GM recommended this years ago when the installed the 17x11 ZR1 offset wheels inthere Big Doggie Vette. Then the Grand SPort offset came out, and voila, perfect fit. I even lowered mine. Look at pics in sig.
Basically you want is about 8.3 inch offset. I think that is what Fikse has , or close to, for the 89-96 Vette. The Grand sport has an additonal 14mm offset from the ZR-1 then the narrowing I do is 13mm more.
In my Imagestaion if you click on the pictures, you can see, if you look at photo in original form as they are huge pics, you can see the fit of the wheels.
Old Feb 8, 2005 | 12:19 AM
aeronautica86
There is one member here who has 335s on the back of his late c4; most will say that 11" rims are too small for 335s but apparently they work OK for street driving; as for them not rubbing, I seem to remember he was happy with them so I suppose they work fine
Old Feb 8, 2005 | 07:43 AM
Mr Mojo's Avatar
Mr Mojo
These are 335's
Old Feb 8, 2005 | 11:30 AM
conv90's Avatar
conv90
see my sig.
Old Feb 8, 2005 | 01:12 PM
kopbet89c4's Avatar
kopbet89c4
Originally Posted by conv90
see my sig.
They look hot. I'm gonna save up some $$$ and get some as soon as I finally burn up my 315 BFG T/A DRs
Old Feb 9, 2005 | 02:11 AM
2blklt4's Avatar
2blklt4
Thanx for all your replies...got some money comming back from the IRS and ill get those 11`s..i`ll finally go for 315`s...they look to kool not to do it.
I`m selling two 9.5`s chrome rims five spoke (zr1 style) with 255`s or 285`s GoodYears HP on them...they have less than 1000 miles on both (rims and tires)
Old Feb 9, 2005 | 03:57 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I have 315 rear and 275 front 17''s 55 mm off set never came close to the flair or the inner shocks ,parking break a little close but the recall took care of that.
To 315`s Question
