WTH... starter wont crank....
Old Feb 7, 2005 | 11:44 AM
korvette4u's Avatar
korvette4u
Default WTH... starter wont crank....
engine just rebuilt...rolls over by hand .. stiff but does..does this mean that the starter is failing? any opion?
btw it worked just fine before.. is there something i missing?
Old Feb 7, 2005 | 12:09 PM
sniperdiver37's Avatar
sniperdiver37
Check power to starter
check for correct wiring
check Batt
Jump the started relay
starter fuse
clean connections
Pull it and bench test it.
I'm guessing you have done all this already....right?
Old Feb 7, 2005 | 12:38 PM
jfb's Avatar
jfb
Could be a lot of things. Battery, battery connections, VATS, clutch safety switch, ignition switch. Check em.
Old Feb 7, 2005 | 03:38 PM
korvette4u's Avatar
korvette4u
do ya think it ay be the starter itself? ya see i forgot to mention we are bypassing the entire system...using a remote starter switch Soo's i can turn over motor to install and fine tune...
what are the thoughts on this dilema?
Old Feb 7, 2005 | 07:40 PM
korvette4u's Avatar
korvette4u
thanks for your suggestions! ....went directly to starter and tested current at terminals..there was ...can see checking all the other items, but is was that gut feeling.....
it was the starter,,,,the solenoid /plugger contacts wore worn out not making contact...replaced 2 copper lugs ... good as new...BUT i ordered new gear drive starter.. WOWOa price here is 379.00$...
thanks again
Old Feb 7, 2005 | 08:41 PM
JCAIRE2's Avatar
JCAIRE2
could have bought a high-quality mini starter for that amount of cash.
Old Feb 7, 2005 | 10:11 PM
korvette4u's Avatar
korvette4u
thats it ...you got it ....good guess
To WTH... starter wont crank....
