Need help with window !!!!
Old Feb 7, 2005 | 10:41 PM
blkc6z51's Avatar
blkc6z51
Default Need help with window !!!!
I went to open the window and heard something go pop, and
now the window won't open. What could it be ?
Thanks for any help.
Richard
Old Feb 7, 2005 | 10:45 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
Default sounds like window track
Does the window motor still run?
Is the window stuck partly up/down?
was anyone shooting at you?
Old Feb 7, 2005 | 10:55 PM
blkc6z51's Avatar
blkc6z51
I can't hear the motor running and the window is all the way up
And no I don't think anyone was shooting at me
Old Feb 7, 2005 | 11:09 PM
e-hodges's Avatar
e-hodges
Default either the motor or the track
motor or track, either way you'l have to take off the door panel to investiage.
The motor and track are together in one assembly.
You need to pull the door skin, a few bolts and *****, wires (about 15 minutes) a few screws are on the bottom of the door I think.
You will find the motor assembly inside the door with the window bolted to the top of it. After you get the door open plug in the switch and watch the motor, you will most likley see the track in two or more pieces, sometimes you can slide the remaining piece back into the motor gear to engage it. If this works the motor is probably OK.
IF the track needs to be replaced you can unbolt the window from the assembly and carefully pull out the window, then unbolt the motor and track from the door and remove it.
The actual repair of the track isnt hard but you will need a big rivet and rivet gun to fasten the new track to to the assembly. and will need to drill out the old rivet to dissemble.
I know it sound s confusing but it will make a lot more sense when you get started.
On a scale of 1 - 10 its about a 5 with a 1 being dip stick check.
Old Feb 7, 2005 | 11:24 PM
blkc6z51's Avatar
blkc6z51
Ok Thanks e-hodges
I'll have to wait till I have some time, I use the car as my D/D
good thing the window is up. I will Retire in March i guess I can
hold off till then.
Richard
To Need help with window !!!!
