comp. ratio????
Old Feb 8, 2005 | 06:54 PM
rugby!'s Avatar
rugby!
Default comp. ratio????
if i am at 10.4 to 1. will i have to run on 92 octane? what ratios for the different grades of gas? if i was 9.5 to 1 could i use 87 or 89 octane?
Old Feb 8, 2005 | 07:01 PM
vader86's Avatar
vader86
At 9.5, you could run either. At 10.5ish, You would need to run 92, but if you could check for knock, then maybe you could find out whether 89 works. Not everybody is going to get knock with 89 on a 10.5, but some will. Depends on your engine.
It all comes down to whether you get knock with that octane level. You want to use the lowest octane you can, that doesnt allow knock.
