fuel pressure question
If you are not holding pressure there is something wrong...
I do similar I also have a extra inline fule pump as well...
It should go to say 60 pounds or whatever ... and usually with mine it may drop slightly lower say minimum of 40 psi.... it willl hold for quite some time... I'm thinking at least 30 minutes... I really never timed it, however it will drop to zero over night.
My fuel pressure gauge is manual with a transducer so it reads whether the car is on or not.
Is there a possibility that when you turn the key off the gauge is also shutting off? ( thought I'd ask...)
If in fact you are still dropping to zero in say less than ten -15 minutes or so, I would say either your regulator is set too low, or you have a leaky injector?
You can fire it up and see what your fuel pressure is showing, it sounds like you stopped the leaks.... if the pressure is too low it will stall too high the injectors will adapt with the PCM.... and you will see it with the gauge...
Hope this helps,
Mo
If you are not holding pressure there is something wrong...Is there a possibility that when you turn the key off the gauge is also shutting off? ( thought I'd ask...)
If the regulator were set too low, he wouldn't see 60# fuel pressure. Which is way too high, by the way.
I'd suggest cranking the engine with the plugs out, to clear the cylinders of raw, liquid, gasoline, to prevent a hydrostatic lock before trying to start it. This is the classic symptom of leaking injector(s).
RACE ON!!!
Polo is supercharged, 60 pounds fuel pressure when you just key on and the system pressurizes is "normal", it returns to 40 ish once the engine fires...
Mo
Be careful the vacum nipple sometimes has to many threads and needs to be ground down to take the presure off the adjustment spring.
In theroy the fuel presure drops so the engine will not start at first ,you crank the key and oil presure builds and then a second or two later the engine fule presure comes up and engine starts.
So you are saying my specific regulator, the Aeromotive LT1 regulator, is designed that way? The other people are saying an injector may be leaking. Do some regulators hold pressure, and others let it bleed off? If this is the case, then I have nothing to worry about. Let me know for sure.
Darren
That regulator is designed that way .
They are for racing and the worst thing in the world is to start a motor and rev it up.
Their design is set so when you turn on the key and dont crank the engine,after about a few seconds the presure will drop.
Then you start cranking the engine and oil presure builds and then the car starts.
That is why you don't crank the key when you first turn it on .
You can over ride it if you turn the key and crank the starter as soon as you turn the key on.
Keeps the crank shaft and bearings from dry starts and prolongs the engine life.
I love mine!
