ZF6 swap spin-off
Old Feb 9, 2005 | 05:17 AM
Bubba91's Avatar
Bubba91
Default ZF6 swap spin-off
Do the Camaros & Firebirds w/LT1's & 6speeds use the same ZF6 as our Corvettes?
If yes, can these be used as donors for us?
What about their rearends... Do they run dana 44's? Are these interchangeable as well?
Old Feb 9, 2005 | 05:30 AM
want2drivemy85's Avatar
want2drivemy85
the camaros and t/a's use a t-56 trans, also they do not have an independent rear end, they still have live axles.
Old Feb 9, 2005 | 09:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
They're different beasts-Sure the swap can be done, but it sounds a lot less troublesome to stick with the ZF
Old Feb 9, 2005 | 09:03 PM
88-406's Avatar
88-406
St. Jude Donor '05
Not trying to start a war, but the ZF-6 was offered in a/some TA's as I recall. Although I think they're proabally pretty hard to find and would cost just as much either way.
Most of the ones you'll come across will have the t-56
KM
Old Feb 9, 2005 | 10:28 PM
MYCoupe's Avatar
MYCoupe
KM
You might be right...I think the first batch of Firehawks that SLP produced used the ZF-6 from the Corvette. These were very limited production so I doubt you'll find one at your local wrecking yard.
Old Feb 10, 2005 | 12:38 AM
bogus's Avatar
bogus
That is correct. I think it was 25. And the motor was a 350hp screamer. These cars are going to be worth 6 figures in no time. More details:
SLP Firehawk Specs
Apparently, there were 27 ordered, 2 were cancelled.
The downside to the ZF6 was cost, and the shifter didn't fit right, so SLP had to some serious modifications to make it work.
The T56 CAN be made to fit the vette, but it requires a special bracket to mount the C-beam up.
Kiesler is selling the TKO, which is a T56 based 6spd for the C4, and it's a full blown drop in. But I don't know if they have a kit for the ZF6 conversion (it's about $3000.00 for their kit - a good deal, really).
They are also doing a 5spd conversion...
My feelings on transmission conversion:
If you are going from auto to manual:
1) ZF6 (this is the best option, really)
2) Kiesler (the 5spd doesn't require cutting, cost effective)
3) T56 (A lot of custom work)
From auto to auto for drag
1) TH350
2) TH400
3) Either with a Gear Vendors overdrive
From manual to manual:
1) Kiesler (the 5spd is a great choice to replace the 4+3)
2) ZF6
3) T56
Old Feb 10, 2005 | 02:47 AM
ninetyfivevette's Avatar
ninetyfivevette
I've got more than that so far into my ZF6 conversion and at the end of the day I've got a used tranny. If I had it to do all over again, I would have gone with the TKO-600. If I manage to kill this ZF6, I can guarantee a TKO will be taking its' place.
Old Feb 10, 2005 | 04:59 AM
Bubba91's Avatar
Bubba91
Thanks y'all
It looks like a TKO will be the ticket, but thats noy for a while now. Will I still need the steering column from a manually equipped car? Is there a parts list of what's needed to complete the swap?
Old Feb 10, 2005 | 05:00 AM
LD85's Avatar
LD85
Old Feb 10, 2005 | 08:15 AM
TONYDEE64's Avatar
TONYDEE64
I actually called them and asked them if this trans would fit in a ZF6 car and they said they didn't know.. acted totally ignorant.... I said "well, if I use a bell housing from a 4+3 set up it should work... right?" uhhhhh. "we don't know". I think it would absolutely work and that's the route I'll go after I kill the ZF6 I already have.
Old Feb 10, 2005 | 08:40 AM
LD85's Avatar
LD85
If anyone wants a copy of a TKO600 quote I got last fall, email me and I will send you an ADOBE copy.
Old Feb 10, 2005 | 01:55 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
2) ZF6
3) T56
Hey, you got somethin against the Richmond
Old Feb 10, 2005 | 02:32 PM
bogus's Avatar
bogus
not really... it's just that the Richmond is rather old school... external linkages, things like that.
Also, the internals are not all that well made, from what I understand.
To ZF6 swap spin-off
