SES Light, Code 11
Old Feb 9, 2005 | 07:55 AM
DutchieC4's Avatar
DutchieC4
2nd Gear
Default SES Light, Code 11
Hi guys. I hope you can point me in the right direction. Intermittently (once / twice a week) the SES light comes on. Usually it's when cruising on the highway with the AC on. I pulled the code using a jumper and I get code 11 (MIL circuit). I also had my mechanic pull the code with a scanner - just to make sure I did the jumper thing right - and he got the same. Now the weird thing is that in the scanner there is an option to turn the MIL (SES or whatever you want to call it) on and off as a test and it passes the test perfectly
'95 A4 with 37k miles on.
TIA
Dutchie
