ZZ4 Cam Question
Old Feb 9, 2005 | 04:56 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default ZZ4 Cam Question
Hi guys,
Anybody have the I/E event numbers for a ZZ4 cam?
I need the cam card data for it if anybody has it or knows where I can get it.
Old Feb 9, 2005 | 05:40 PM
SS409 425HP's Avatar
SS409 425HP
I got this from a previous post here about a year ago. I believe its accurate.
IVO (BTDC)-5.0
IVC (ABDC)+33.0
EVO (BBDC)+45.5
EVC (ATDC)-4.5
Old Feb 9, 2005 | 05:49 PM
94brick's Avatar
94brick
Is this cam the same as the ZZ409 from TPIS? I have heard thats its similar to the Hotcam but produces more low and midrange torque without sacrificing anything on the top end.
Old Feb 9, 2005 | 06:04 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
This may be another one of my apples ot oranges comparisons, but my days in the Fbody world I have seen people who were not happy wiht the results of the ZZ4 cam in an EFI application. I unfortunately do not have any real data on this... just heard the complaints. I just thought I'd pass it along.
Old Feb 9, 2005 | 06:10 PM
94brick's Avatar
94brick
Good to hear both sides. Jim I hope I didn't hi-jack your thread.
Old Feb 9, 2005 | 07:00 PM
JOHN89's Avatar
JOHN89
I ran this cam for 3 years. The intake duration and lift are somewhat lacking at 208* and 0.474". The exhaust was pretty good though at 221* with 0.510". The cam will quickly become the limiting factor when you start modding the intake and exhaust due to the small intake duration.
If I could do it all over I would have went with a 219 LPE for a 350.
Old Feb 9, 2005 | 10:16 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Hey guys,
Thanks for the info.
No concern about hijacking here. It's ALL good information.
I can "create" cam card , I/E event data, etc, from the cam itself but that doesn't tell me if the cam is what was intended.
But I really wanted the cam data for degree purposes.
I have the cam and am going to try it out and see how I like it.
The Lingelfelter 219 does look like a good cam but it cost about three times as much as the ZZ4 cam.... Maybe I'll get one of those later.
Ditto on the TPIS ZZ9. Looks good.
I like the HOT Cam but the lift on it is getting 'out' there a ways for my Z28 valve springs.
Unless you get the whole kit it looks like a coil bind monster.
The ZZ4 looked like a good 'compromise' cam. Not as much duration and lift as the HOT Cam but easier to work with.
I have a Crane cam in my truck that idles like a Harley. Long ago forgot the details on it. Lopes like a kangaroo.
Converted it to TPI last year and after 32 chip burns it runs great. That cam was made back around 1975 before EFI came along.
It really wasn't that hard to tune.
SS409, I'll use those numbers and see if the cam conforms to them.
Pace, Scoggin-Dickey and Greenwood don't seem to publish all the data for this cam for some reason.
Old Feb 9, 2005 | 10:40 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Here is the info of the SDPC site on the ZZ4 Cam:
SDPC Part Number: 10185071
Manufacturer: GM Performance Parts
Duration @ 0.050" Lift : 208/221
Valve Lift : .474"/.510"
Lobe Seperation Angle (LSA) : 112
RPM Range : 1500-5500
Camshaft Type : Hydraulic roller tappet
Here is the LT4 Hot Cam Specifications:
24502586 Hydraulic Roller (LT4 Hot Cam)
(intake/exhaust) is 279/287;
duration at .050" tappet lift (intake/exhaust) is 218/228lift with 1.6 (intake/exhaust) is 525/525.
lobe centerline is 112 degrees.
Here's the cam specs. off TPIS site:
ZZ-9 HydraulicRoller:
Adv. duration 282 287
Duration at .050 212 226
Gross lift .483 .520
Lobe separation 112
ZZ-409 Hyd Roller:
Adv. duration 287/287
duration @.050 226/226
Lift .520/.520.
112 LSA.
ZZ-9X Hyd Roller:
duration @.050 225/240
Lift .525/.558
112 LSA.
ZZ-X Hyd Roller:
Adv duration 290/290
duration @.050 239/239
Lift .558/.558
112LSA.
Here's Lingenfelters Cam Data:
74211 - SBC 305-383 211/219 .530/.560 w 1.6 rocker 112 CL
74216 - SBC 305-420 213/219 .493/.502 w 1.6 rocker 112 CL
74219 - SBC 350-420 219/219 .560/.560 w 1.6 rocker 112 CL
74220 - SBC 350-420 215/220 .540/.555 w 1.6 114
The ZZ4 cam does measure in as a lightweight compared to these other cams.
I may have to bite the bullet and go with the Hot Cam or a Lingenfelter 219 cam.
I'm looking to make 400~425 HP.
The ZZ4 cam may get close but I'm thinking it will come in around 360~375 HP.
Here's my combo:
.060 350 block
3.75 Stroke Eagle Crank
Edelbrock Performer RPM Heads 64CC
Speed Pro Pistons Flat Top
Compression 10.5 +/- .5 (don't know exactly yet)
To ZZ4 Cam Question
