egr removal 92
1) It doesn't hurt performance, at wide-open-throttle, it is turned off by the ECM anyway.
2) Some vehicles experience detonation without EGR, because the EGR keeps the peak combustion chamber temperature down and prevents it.
3) Obviously, emissions.
There normally isn't any compelling reasons to eliminate it, but there are some good ones to keep it.
But, if you have a performance cam that has enough overlap to give you "internal" EGR, I do wonder if you could have too much EGR.
The LT4 doesn't have an EGR system because of the cam.
Tom Piper
But, I'm not running EGR on my 355 TPI engine in my old '73 Super Cheyenne truck. Engine runs GREAT. No pinging (although I always run 91 RON)
It doesn't have all those sooty,nasty deposits in the intake tract either.
Don't have it on my '84 Vette either. It runs GREAT and seems to have never missed having it.
Still have it on my '91 Vette but it's not going to be there much longer.
It makes the intake tract look like Hiroshima after the bomb. N-a-s-t-y.
Reintroducing into my engine stuff that's supposed to go out the tailpipe can't be something that I REALLY want.
I know the bennys of running it and have read all the reasons and most point to reduced NOX emmissions.
Not to appear to be unkind to the environment but the air quality in my part of the country is way up there with the best of'em.
A little more NOX from the exhasust of my Vette, that gets driven once a week at best, isn't going to kill any trees,pets or humans.
It's not going to destroy the ozone as much as those big Stupid Ugly Vehicles either.
Flame suit on.
Edit: Uh-Oh, I DO have that 'Internal EGR' thing on my truck that Tom talks about in his post . Gotta LOVE that idle sound!!
Removing EGR/AIR might not give any power but it damn sure makes everything in the engine compartment easier to work with. I am very happy now that my system is gone for good. (Just my opinion and I'm not trying to start a war
You have to get custom tuning to tell the ECM the EGR/AIR stuff is gone so it won't throw a code. Forum member Ski_Dwn_it can burn your chip in your ECM to remove this system. I would contact him. After that, trace all the parts of the system and get rid of em. The M-22 Oil drain plug is the only thing I found which fit the holes in the manifolds. You can get it at Napa.
I DO care about the environment, but the car is not a daily driver.
Mark
on there I probably need to pull off. I was looking at it and I wasn't really sure what the heck anything was so I was afraid to take stuff off
It was funny after the EGR stuff was removed and I was driving around with my new engine I hear this high pitched whistling noise and I'm like WTF is that? I looked and it was the air pump running because it was still plugged in it was just pumping air nowhere.
Yeah 92's even have a specific little fella under the ASR which you can pull along with the AIR pump. I put my MSD ignition where the electric AIR pump used to be!
The AIR pump introduces fresh air into the exhaust to heat up the cats faster.
The EGR is used whenever to keep combustion temps down and reduce NOX emissions.
The Secondary Air Injection (AIR) system helps reduce Hydrocarbon (HC), Carbon Monoxide (CO) and Oxides of Nitrogen (NOx) exhaust emissions. It also heats up the three-way catalytic converter quickly on engine start-up so conversion of exhaust gases can occur sooner.
I'm not sure where I read that about it helping improve emissions on cold start.
well said!
The reasons not to eliminate the EGR or AIR:
1) Emissions
2) Doesn't hurt perfomance at all.
3) Federal law against it -- probably would never get caught, but not worth it since it doesn't hurt anything. Could get fined even in a state without emission inspection.
4) Resell value.
5) My state may someday start to require emissions inspection.
The reasons to eliminate it:
1) With performance cam, may have too much EGR -- this is the only reason I considered.
2) Easier to work around -- not very compelling to me.
3) Weight reduction -- since I don't race, I would be interested in lbs not ounces in weight reduction.
Tom Piper
