Automatic Transmission Problem
Old Feb 11, 2005 | 07:36 AM
Big_John's Avatar
Big_John
Default Automatic Transmission Problem
I had a problem with my 91 C4 that occured several times last summer when the temperature was in the 90's or above. After driving for a while, the trans started slipping in reverse. Not real bad, just enough to notice when I was backing out of my driveway uphill to the road.
All else seems fine, shifts OK, perhaps not quite as crisp when its hot, other than that, its fine. Never any problems in reverse when the car is cold. The car has 55K miles on it. Any ideas?
I'd like to get this figured out before I get the car out this spring.
Old Feb 11, 2005 | 08:19 AM
Pete K's Avatar
Pete K
Hopefully your problem is as simple as a valve hanging up a bit in the valve body. This can be dropped and cleaned without dropping trans. It could be as serious as worn clutches.
The atsc shop manual lists about 20 or more possibilities for slipping in reverse. If you like I can start listing them. Most are bad news so I won't list them to depress you unless you wish.
Old Feb 11, 2005 | 02:15 PM
Big_John's Avatar
Big_John
I'm kind of hoping that its something simple. I was planning to change the trans fluid this spring anyway, so dropping the pan is no big deal. I've rebuilt a couple of Torqueflites back when the dinosaurs roamed the earth, so I'm not scared of having to get serious about this if need be. Go ahead and give me the news straight, but I'd still like to try the easy stuff first. I have read that the separator plate in the valve body tends to wear and replacing that isn't a bad idea.
By the way, my in-laws live in Nanticoke.
Old Feb 11, 2005 | 02:37 PM
fast.asleep's Avatar
fast.asleep
I was told that transmission slippage backing up a hill was a signal that yuor tourque converter is on it's last legs
Old Feb 11, 2005 | 05:45 PM
Pete K's Avatar
Pete K
Boy, small world. I have met a few forum members who, by coincidence have roots in the wyoming valley. Hopefully your problem is simple. It never is for me. The seperator plate does wear out. The 87 and later models use a specific plate to match each specific valve body. It has a 2 letter code stamped into it. Do not use a generic plate. Buy the exact one from the dealer after you remove yours and confirm the code. I have part numbers to match each letter code if your dealer parts guy is stupid. The reverse boost valve is another easy to check part after pan is down. It can be removed from the pump through the bottom easily. 2-3 shift valve in valve body is another. The last easy possibility is the lo overrun valve in the aux valve body could be sticky. Good luck! Pete
Old Feb 11, 2005 | 08:40 PM
Big_John's Avatar
Big_John
Thanks Pete for the help and especially for that piece of information. I was all set to buy a generic one.
To Automatic Transmission Problem
