Water Pump Drive Sleeve install Direction
Old Feb 11, 2005 | 12:00 PM
BIGJIM13's Avatar
BIGJIM13
Default Water Pump Drive Sleeve install Direction
HI
On a 93 Corvette which way does the water pump drive sleeve/coupling install - does the end with the grove go towards the engine or towards the pump?
Thanks much for any help
Old Feb 12, 2005 | 01:43 AM
MaxLean's Avatar
MaxLean
I don't think it makes any difference. I've always just installed without considering it.
Old Feb 12, 2005 | 11:55 AM
GS345's Avatar
GS345
St. Jude Donor '11
Originally Posted by BIGJIM13
HI
Put a little grease on the spline and install the grove towards the engine.
jeff
Old Feb 14, 2005 | 09:44 AM
BIGJIM13's Avatar
BIGJIM13
Default Water Pump Drive coupling direction
Jeff
are you sure - another guy said the other way
To Water Pump Drive Sleeve install Direction
