I got a new set of Kuhmos on and I want to get an alignment to ensure even tire wear and proper handling. I found some info searching the archives, but would like some additional info/opinions. Here is the chart I found:
i use those settings on my daily driver, which i also autocross often. very good for the street, but i wish i had more negative camber in the autocrosses.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by qwik96GS
You can easily run -1 camber on the street without too much additional wear. Toe is much more a factor of wear than camber is...
If you have larger, i.e. 315's, tires on the back you are going to want to run more negative camber on the rear camber.
I've run the advanced street set-up for some time. In fact I wore out a set of Kumho MXs with the set up. I was thinking of going with more negative camber because my fronts still wore a little more on the outer edge. Around here you're in a curve as often as not and I also tend to enjoy the curves on a regular basis. So would you think I'd be good with 1 degree negative on all four corners then? I'm using ZO6 wheels so I have 295/35/18s rear and 275/40/17s in the front.
When I had new tires installed a year ago.
I had complete alignment,done by a tech who used to work for Chevy.
This was done at National Tire, maybe I was lucky , but the print-out, I was given was exact to the Corvette specs.
He spent about 1 hour, & i was very pleased.
The computer specs at NT where right on the money.
Usually you can run more on the fron than the rear. Both adjustments to camber are relatively easy to do yourself. The rear is simply loosening a bolt and making an adjustment. There are even marks on it and each one is about a degree of camber. The front uses shims, but making the adjustment can affect toe slightly. I know many people at the track who adjust to much more negative camber in the rear before the event, some even remove shims on the front. At the end of the event they put everything back to a little less negative camber.
