troubleshooting overheating
I cannot find a leak of any sort.
No combustion residue in coolant.
pulled the plugs and i see nothing that would lead me to believe im getting water leakage there...
Get that test kit.
And you won't get greasy. :
Here you go:
http://jcsonlinetoolshed.com/product...052fa1950cf4e6
It will give you a definitive answer if your head gasket is bad causing exhaust gases in the coolant. That would explain your loss of coolant.
Given that you've been adding fresh fluid to it I don't know how accurate the combustion residue test is. I'd do a pressure test of the cooling system and/or leakdown tests of the cylinders.
Get that test kit.
Here you go:
It will give you a definitive answer if your head gasket is bad causing exhaust gases in the coolant. That would explain your loss of coolant. How did you determine that there was no "no combustion in the coolant"? This use of this test with the blue dye leaves no doubt one way or the other. IMHO its $30. well spent rather than throwing parts at it.
driving normally at 70MPH ... constant 200 degrees (about 18-2000 RPMS
pull it down into 3rd gear
and the RPMS jump to about 3k.
TEMPS start dropping and hold at around 194.
back to overdrive ... and temps slow climb back to 200 steady.
/shrug new waterpump and thermo are on the way just in case from GM parts direct...
What the heck ... replacing them 1st .. next will be a radiator from Dewitts
Jeff
At least have a leak test done on the system just to ensure you don't have a leak somewhere.
~B~
Increase CFM
helps prevent road trash and water contamination
Increase recovery time
decrease coolant temps
and Looks coool !
http://www.C4orceCorvette.com/testimonials.htm
Big Mouth Air Dam !
Your right thou fresh coolant could throw it off .
good news hearing the temps on rising RPMs are fairly normal.
I have found a leak finally.... I hope its all i need for now ..
The ring under the surge cap tank ... where the metal meets plastic.
I can turn that by hand a bit .. and there definately some leakage coming form there.
Im thinking thermo stuck .. heated it up real good ... the added heat opens that space up to allow lots of coolant out when under high temps and pressure.
Idle in the garage with cool temp and low pressure it doesnt leak however .. i gave it a good run home, when almost home blocked off part the radiator so i could get temps around 220 solid and found more than a drip ... less than a stream coming out.
for now ill use the new thermo and save the new pump on whatever rebuild/repalcement i finally decided on ... something 400hp+ im thinking before the years out
