headlight adjustment????help please
Anyway, I got it all hooked back up and installed, but in the closed position, the light isn't sitting flush with the hood like it did before. The gaps are even all the way around, it's just not sitting level, the oustide edge is about a 1/4 inch or so lower than the hood. I see the bumpstop adjustment....but that adjusting didn't seem to be enough, it only adjusted the top and bottom edge, but what about the side to side edges?....are there any other adjustments? or other things to look for?
Thanks.
Adam
93
These can be used to adjust the light housing to the frame.
Thanks.
Adam
93
On the 86 there are four bolts with 10 mm heads that are used to adjust the flat headlight cover (if that's what't your referring to). It's the cover you see when the lights are in the down "OFF" position.,
You need to raise the hood. The pull the headlight switch to "ON", but push it to 'PARK" (parking light setting) when the lights are half open. This will give you access to the four screws that hold the headlight hood in place. Remove the four screws that hold the headlight hood (this is the one you see when the lights are "ON") in place to gain access to the two forward most adjustment screws for the flat headlight cover.
Now, with that done, you lossen the four 10 mm screws that mount the flat cover Move the flat cover in the needed direction, using your hand on the hood to determine when it's level. Slowing tighen the 10 mm screws continually checking for correct alighment with the hood.
Re-install the hood and it's four screws (mine calls for a torx head bit) and align it so that when the headlight are in the up "ON" position, the lowest lip (sorry don't know what GM calls it) of the hood is flush with the hood line.
They may be called bezels (what I referred to as "hood")
Hope this helps.
Jake
I am not sure if that means anything or not, but I had level doors each time when finished.
Boatman
