lay down radiator
Old Feb 12, 2005 | 12:24 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default lay down radiator
I've the radiator layed down, so it's horizontal, both on SpeedGT cars, and on a supercharger Mallet car done up for the One Lap race.
Why?
It makes a lot more room, and seems to flow better.
Think about all the space you'd have infront of the engine doing it.
Plenty of room for a blower, turbo, intercooler.
And, since heat rises, it would flow air through the radiator naturally.
Downside?
The radiator would get smashed in accident.
Where to relocate the aircleaner?
The SpeedGT cars run a heat insulated pipe to where the front plate is.
The superchargered car air intake is relocated anyways.
Thoughts?
Old Feb 12, 2005 | 12:36 AM
Mo_Bandy's Avatar
Mo_Bandy
Brian,
You know that sounds very interesting...
The chances of the radiator getting crunched in an accident is probably a given anyway. I would think that if it were pitched at the angle of the airflow it may be even more efficient...
Something to munch on...
Mo
Old Feb 13, 2005 | 03:20 AM
bill mcdonald's Avatar
bill mcdonald
it is also layed down, but not parallel to the ground on the sledgehammer, and a one off callaway did on a production B2K. and a car that ran the silver state whatever race. (My brain is not working now for some reason, I cant remember anything).
anyhow it was a BB C4 that hit 235 there. they tilted the top of the radiator forward, and the heat extractor in the hood took the heat right out.
Also I have been looking at the build up on American hot rod of the TT 65 vette. it looks to be getting some radiator mods as for teh way the intercoolers are now.
I have been wondering about taking some idea like this and putting it to work.
Old Feb 13, 2005 | 09:23 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Put your air filter under one of the headlights
Old Feb 14, 2005 | 12:52 AM
Mo_Bandy's Avatar
Mo_Bandy
That would realy help with the S/C openup some room... I've been following that as well god build up I'm anxious to see how it finishes...
Mo
Old Feb 18, 2005 | 01:58 AM
TIMSPEED's Avatar
TIMSPEED
Isn't the radiator in an LT1 car already laid at an angle...like 70º?
Old Feb 18, 2005 | 07:52 AM
chuntington101's Avatar
chuntington101
IMO the best setups have the rad **** over at about 45degree angle. this gives you a much larger surface area for the same frontal area as a vertical rad. the problem is that it intrudes into the engine bay! i have seen this set up used alot on rally cars over here (uk) where they mount HUGE intercoolers in font of them and really **** them over!
also you could look into mounting one rad at the front, and another at the rear. lag the rear one flat and stick a bog fan on the top of it. then cut a hole in the underside and there you have it. it may sound a bit crazy (and it is) but it works well as an additional rad.
thanks Chris.
Old Feb 18, 2005 | 01:43 PM
bill mcdonald
I guess if you mean layed back about 20-30 degrees. it is like this on my 90 as well. it really makes the front of the engine look crowded compared to the early C4's
Old Feb 18, 2005 | 07:27 PM
Positive Pressure's Avatar
Positive Pressure
Bill do you have a picture?
Old Feb 19, 2005 | 11:06 PM
BrianCunningham
They just rolled it out today, quite impressive!
http://www.nelsonracingengines.com/press_ahr.html
Though I think I like the stock dash better. IMHO
Old Feb 20, 2005 | 02:35 AM
Mo_Bandy's Avatar
Mo_Bandy
I could really use the extra extra space bigtime...
Mo
To lay down radiator
