It seems that know one sells a flexplate for internal balanced 1 piece rear main 350's. Any have a source that does? Thanks.
Is there a reason not to use the old plate, or a stock replacement, if the old one was worn out? Was it balanced, truly neutral? Or unbalanced for the one piece seal, unbalance?
Can't use my old one because it's for a 2 piece exernally balanced engine. My new engine combo calls for a neutral balanced flexplate for a 1 piece rear main (has to be SFI certified as well).
That will be a search! And it will be compounded if you want one with 168 teeth. GM never made a neutral balance flexplate for a one piece seal crank. All production one piece seal engines have imbalance in the rear due to the different shape of the crank flange. If that is REALLY what you need, you will probably have to get an SFI plate and HAVE it neutral balanced. Don't confuse the term "internal balance" with "true balance".
I bought 2 flexplates, both were from GM and both were made for an internally balanced 1-piece rear main seal. I have a ZZ4 short block and they require the flexplate. I have a flexplate that is brand new for a internally balanced 1-piece rear main seal if you want, I bought it for my previous starter but never used it, it is a 168 tooth flexplate. The bad thing about the GM flexplates are that they are made for TC's with the 12" or 13" bolt pattern and on the one I have on my car now I had to drill 3 new holes for my smaller TC. The 168 tooth flexplate is untouched, if you want it let me know. If not then you can get the same ones I have through GM performance parts. Good luck.
Crap! You learn something new every day. Okay, to be a little more specific this flexplate will be going on a factory ZZ4 shortblock. So this will require I use ex. balanced flexplate? Also, I already have a powermaster XS starter for a 153 tooth so I obviously can't use a 168 tooth FP
Thanks for the offer but like I stated in my above post, I need a 153 tooth flexplate.
On a factory engine with a one piece seal crank, all you need is a stock one piece seal crank flexplate (plus the SFI rating). One piece seal engines are not truly, 100%, internally balanced. There is a slight imbalance in the rear with the one piece seal that is compensated for with a slight imbalance in the flywheel/flexplate. Like an external balanced 400, but much, much, less. The problem comes when/if someone has a one piece seal crank truly, 100% internally, balanced. Then they have to have an unbalanced stock 'wheel/'plate, neutrally balanced. YOU should have no problems. Any 1986-up, 153 tooth flexplate with an SFI certification will work fine.
Sorry if I caused any panic, but the initial post of a one piece seal engine, "internally balanced", left doubt for the possibility of a mismatch. That really isn't what you have.
