TB Interchange Question
Old Feb 12, 2005 | 08:37 PM
DrEvil11417's Avatar
DrEvil11417
Default TB Interchange Question
I just picked up a BBK 52mm TB for my '86
But the TB came off a '92 F-body, will I have any problems getting it working?
Old Feb 12, 2005 | 09:15 PM
bogus's Avatar
bogus
that should work ok...
Old Feb 12, 2005 | 10:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The early plenum ('85-'88) has a triangular hole in the front of the plenum between and below the two air inlet ports which is not found in later model plenums.
For this reason the late model TB will work with the early plenum but the reverse is not true.
So the TB for the '92 L98 should work with your '86 L98.
Old Feb 12, 2005 | 10:22 PM
KENS80V's Avatar
KENS80V
You might need an accelerator cable for a 89/91 Vette as the linkage on the 89 and up throttle bodies is different (smoother acting) curved.
Old Feb 14, 2005 | 01:58 PM
DrEvil11417
Yeah, that's the only difference i saw
plus the TB is going on an lt-1 intake so im not worried about plenums matching :-D
To TB Interchange Question
