Power brake booster
Old Feb 12, 2005 | 09:56 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default Power brake booster
I just ordered a power brake booster from Mid America for my 86 coupe. is there anything I should know about changing this out.
Old Feb 13, 2005 | 01:22 AM
bogus's Avatar
bogus
just a few bolts, most of which can be a bitch to reach, cause they are under the dash.
you should not have to remove the lines to the master cylinder, this will mean you don't have to bleed the system later.
Old Feb 13, 2005 | 02:41 AM
subman's Avatar
subman
Here's a link to the tech tip.
https://www.corvetteforum.com/techti...=281&TopicID=2
Some have found it easier to remove the front seat, but no matter how you work it, you have to be a bit of a contortionist.
good luck!
To Power brake booster
