Head Gasket Installation Question
Old Feb 13, 2005 | 09:10 PM
90Indy's Avatar
90Indy
Default Head Gasket Installation Question
I will be getting my heads back from Precision Porting any day now. I have a 90 L98 and need to know if anyone uses gasket sealer? The gasket manufacturer says I don't need to use any but I thought I would ask for a second opinion.
Thanks.
90Indy
Old Feb 13, 2005 | 09:12 PM
96GS#007's Avatar
96GS#007
Head gaskets get installed dry.
Old Feb 13, 2005 | 09:24 PM
aboatguy's Avatar
aboatguy
He's right, use a quality head gasket and install it dry.
Old Feb 13, 2005 | 10:02 PM
Chris89GTA's Avatar
Chris89GTA
Some people will use the gasket sealer if there is any question about the block or heads being true and flat. Assuming they are then do it dry. Mine weren't "perfect" in the TA but they sealed fine dry.
Old Feb 13, 2005 | 10:53 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The only time I use sealer is when the deck is pitted or otherwise compromised such as on some of the ancient diesels that I repair sometimes. It can help with such minor surface imperfections but if trueness is not in spec it could not help with that, I believe. I never use it on anything that I'm allowed to repair properly, it's not necessary.
Old Feb 14, 2005 | 08:18 AM
WNDOPDLR's Avatar
WNDOPDLR
All above are correct, but don't forget that SBC head bolts have wet feet. Be sure to use a sealer such as Permatex High Temperature Thread Sealent on the threads of the head bolts. I use the same stuff around the intake manifold bolts and it helps prevent the oil misting around tose bolts.
Old Feb 14, 2005 | 12:50 PM
90Indy's Avatar
90Indy
Thanks for the info. They will be installed dry.
90Indy
To Head Gasket Installation Question
