Ok, at this point I'm fairly certain its time for a new head gasket on my '88. Fortunatly, I have my handly Helms manual, and a reasonably competent son-in-law, so we are going to tackle this project ourselves.
So - here go the questions.
1) Logic says we replace both sides as long we are tearing everything down - correct?
2) Since we will have the heads off anyway - is there anything special we should do with them - ie. is there any reason to send them out to a machine shop? What are the options for head work and what kind of costs?
3) What else should we be looking at since she'll be opened up?
car is an '88 vert, automatic - ALL STOCK. 60K I expect she will stay stock, with the possible exception of an exhaust system.
I am doing this too. (89 auto - thankfully not mine!)
1) Definitely. You are so nearly there with the manifold off and everything, not worth the risk of not checking both sides.
First, it may be the head gasket, in my case there is also a crack in one of the heads - which leads to -
2) while the heads are off, may as well put in new valve seals and grind the valves in, and while the valves are out send the heads for crack detection/skimming/valve guide inserts as necessary - after that performance stuff as suggested above
3) check bores for scoring, excessive wear (fingernail test at top of bore), broken top rings (flashlight and better eyes than mine), piston cracks etc.
Reason: typos
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Britvette brings up a good point. You might as well have them magnafluxed and checked for cracks while there off. Cheap insurance.
They’ll probable even hot-tank em for you.
Since the heads are comming off:
-5-angle valve job
-2.00/1.56 valves
-hand pocket port
-1.6:1 ProMagnum RRs with Comp Cams 981 springs
Since you are doing the work, you only need to shape the valve guide boses, blend the seats into the bowls and remove any casting flashes for some gains.
The head work will gain 20-30hp, depending on how much porting is done; the RRs are worth 15chp.
You will get some of the benefit from those mods after you do the exhaust work.
BTW, while the hood is open, toss the "frisbee" from the front of the water pump pulley for a 10hp gain.
No - she's never overheated. I've been dealing with a "low coolant" light for a few months now, thought at first it was air in the system (burped it), or a defective sensor, but Saturday I noticed the green "Drip drip" up the the car after driving. An inspection found a small amount of coolant on the top of the engine near the #8 cylinder. I still want to pump it up with a pressure tester before tearing it all down, but I'm assuming thats the problem. I've alos started to notice more "white smoke" during warm-up, which since its winter I discounted at first, but now it looks like - well, you know.
Is it possible that the coolant is comming up around the rear intake base bolt as there is a steam vent near that bolt.
Interesting - then I guess the question is a) is there a way to determine whether its the gasket or simply the bolt without disassembing everything? b) If everything has to be disassembled anyway would there be any reason not to just replace the gasket at that point?
My 85 had the same symptoms and it was the intake gasket. leaking from all over the place - in and out. I'm a wannabe mechanic at best, but wouldn't a compression test help with the diagnosis of the head gasket?
If it isn't broken, don't fix it. That's my motto.
As for determining where the leak is. Pressurize the cooling system with a pressure tester( usually one can be rented from the local parts house. For example autozone will rent one for $25, you bring it back and your $25 is returned to you) and remove the sparkplug for the cylinders in the area of the leak. Once pressure has bled down a little, crank the engine over and see if coolant comes out the plug holes.
If it's the intake manifold, try tighenting the bolts before doing anything else, that may be enough to seal the leak.
I agree with JCAIRE2 and viii.. when I did my injectors, I decided to
check the torque on the intake (as I had done the intake gasket about
2 years previous).. Half of the bolts were loose where i could spin them
by hand.. Sounds like intake to me too...
While that might help, a better idea is to use a block tester...drain some coolant out (so as not to contaminate the test fluid), let it warm up, and check for combustion leaks (fluid turns from blue to yellow - uh oh!). Most leaks on L98's are from the intake manifold tho...if it's leaking preyty good already, simply tightening the bolts is a stopgap...you're going to have to go in sooner or later.
my L98 had both the intake leak, that I first fixed, then 6 months later paid to have the intake removed again to find I had the dreaded headgasket leak at the back of the cylinders. A combustion check as well as checking the antifreeze leaking out of the sparkplug hole once the engine was warm. My antifreeze leak never turned the oil funny colors, it just burnt off. Defintiely get heads checked by machine shop and go with there reccomendation for cleaning and redoing the rubber seals on the valves. The roller rockers and custom valve j0bs, and stronger springs only matter if your going for every bit of speed available. Otherwise it is a lot of money for little results. You could spend literally thousands on new heads, special porting jobs and new larger springs and valves. Do you just want the car to run well again at the lowest possible cost or do you want to sink a bunch of money, into a never ending project???
