My power seat switch is getting very flaky. I know the motor still work because I hooked up the 12V to the motors to move the driver seat back since the switch didn't work.
I'm trying to see if I can clean the contacts or something. I've got it out of the bracket that it mounts in but I can't seem to get it a part anymore. Has anybody done this before? Is there a trick that I'm missing? Please Help!
I resurrected a plastic sealed switch by drilling a couple small holes in it and injecting it with tuner cleaner, then forced compressed air through it to empty it out. Plus a little WD40 for good luck. It snapped right out of it's funk and worked fine. I was going to toss it so it would have been no loss anyway.
Try that before you throw it away. If there is no mechanical damage in there, it will most likely work.
You can put a little caulk or sealant in the holes to complete it.
I'm pretty mechanically inclined, but being that the wires are soldered on I'm doing this in the dim garage, lying sideways because the set is out, and not having much manuvering room between the roof, steeringwheel and the console lid.
I'm down to just the black casing with the wireleads on it. But I'm not sure where to go from there. All the casing stuff used to mount it to the plastic bracks are gone, undid all the screws and pulled the switch out, now I'm not exactly sure how to get the switch itself apart.
before anyone throws away the switch I need one of the little gray triangles on the switch cover that sits on top of the counsole. I am missing one! You guys can email me a prodadiv@yahoo.com.
Are you sure they are soldered on? On my 88 the wires go to the sockets and the switches are connected to the sockets with large 3/8in. pins. I separated mine with a small flat blade screwdriver. (dont touch the pins together ;-) )
There are 9 pins, power, ground, something else and 6 that go to the three motors in pairs. These pairs can switch polarity depending on how you want to move the motor. Between each of these pairs is a soldered on capacitor. The solder goes through the center hole on the pin and is messy enough to get onto the wire connector. I gave it a good yank with a pair of pliars and the thing wouldn't budge. I don't really want to resolder the caps back on if I can avoid it.
I just tested out one of my power seat switches after trying this and it worked nicely! I'm stoked, this is going to save me about $80 that I can now spend on other car stuff. Thanks for the advice!
You are now qualified to join the jimmie-rig club. I am a charter member. I think it's fun to see what you can do with tuner cleaner and WD40 and some tape and caulk.
Look at all the money you saved. You can buy your girlfriend a big French dinner.
Or maybe some new mats for the front......
