Stroker Kit?
Old Feb 15, 2005 | 06:57 AM
ALLT4's Avatar
ALLT4
Default Stroker Kit?
Just thought I'd throw this out there and see what you all think. Would this be OK on an otherwise stock LT1?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Feb 15, 2005 | 09:02 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
#1 Make sure it will work with a small basecircle camshaft.
#2 You will have to clearance your block
#3 You will likely have to change your flexplate and harmonic damper
(or your flywheel/pressure plate and harmonic damper)Ask them about this
#4 Have them balance your parts. Send them your damper and flywheel.
Have those 'zero balanced' if possible and not balanced with the rotating assembly. ( if you can )
Old Feb 15, 2005 | 10:50 PM
TwoFast4Lv's Avatar
TwoFast4Lv
I buy kits from them. they fit great we have been using 1.00 base with no problems
To Stroker Kit?
