elec short shutting down Vette
Old Feb 15, 2005 | 01:49 PM
prodadiv's Avatar
prodadiv
Default elec short shutting down Vette
I've had a bad problem with my 1990 Vette. The motor runs fine but
after a few minutes the alternator switches and puts out 20V shutting down the car. I have had two different mechanics look into this both costing be a small fortune. Aside form the guage fuse or grounding which both seem to be good what else can associated with this?
Please help!
I can also be reached at prodadiv@yahoo.com
thx
Pete
Old Feb 15, 2005 | 03:24 PM
jfb's Avatar
jfb
If that is really happening, your voltage regulator in the alternator is defective and it can be replaced or you can just replace the alternator with a rebuilt one. 20 volts will burn out the MOV (metal oxide varistor) that protects the switching supply on one of the dash cluster boards and smoke will come out of the dash.
I question that 20 volts across the battery really occurs because you would also be complaing about burned out everything electrical, radio, headlights, dash lights, etc.
Old Feb 15, 2005 | 03:33 PM
prodadiv's Avatar
prodadiv
thanks for your input. The alternator has been replaced twice for obvious reasons. The ECM senses the spike and shuts the car down. This seems to be a protection that Vettes have.
I think this shut down occurs out side of the 9-16 volt limit.
Old Feb 15, 2005 | 04:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
There's two fusible links on the car, if one goes it won't charge, if the other goes it over charges like you described. Take a look and see what condition they are in.
Old Feb 15, 2005 | 07:54 PM
prodadiv's Avatar
prodadiv
one of the fusible links are missing under the brake booster.
Where are the fusible links located that will do what you are
refering to?
This may help!
Old Feb 15, 2005 | 07:59 PM
JOliver's Avatar
JOliver
behind the battery on your 90 there will be a distribution block,that has a bunch of wires attached to the top of it.Those are the fuse links,they look like a normal wire with a bulge in them.
Check them out very well,I had a similar problem with my 90 I found the bad one by slighty pulling on it it came apart in my hand replaced it and all is well.
Good luck keep us posted
Jason
Old Feb 15, 2005 | 08:01 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
WOW! Can we make a sticky note for this one????
Old Feb 15, 2005 | 10:22 PM
prodadiv's Avatar
prodadiv
do you know what the amperage rating is on the fusible links?
again thanks!
Old Feb 16, 2005 | 02:11 PM
BrianCunningham
again thanks!
It varies for year to year. You need to get the correct one, since your playing with fire literally! There's been some forum members that have lost thier cars to sudden engine compart fires. That link is right next to the battery. Make sure it's tucked up away from it. I've had mine melt into the battery they can get that hot.
Old Feb 16, 2005 | 04:06 PM
prodadiv's Avatar
prodadiv
I'm about to give up on this car! The fusible links seem to be good and two mechanics wanted a blank check in order to probe around with no guarantees. This has already cost me $1150.00
To elec short shutting down Vette
