How do I install a trans cooler?
Old Feb 16, 2005 | 12:15 AM
darkman5001's Avatar
darkman5001
Default How do I install a trans cooler?
I am upgrading to a Torque Master torque converter that stalls between 2800-3200 stall. I have been told that the B&M super cooler would be ideal and do the job for cooling. Any comments? Will this thing just bolt right in, or will I have to drill holes? If I want to mount a fan on it later, how hard would that be? How do I connect the cooler to the transmission? Any other suggestions? Thanks!
Old Feb 16, 2005 | 01:15 PM
Mo_Bandy's Avatar
Mo_Bandy
Darkman,
It is actuall prety simple to install. I used the mounting hardware and mounted the cooler using the screws in the skirt in front of the Radiator/ condenser...
It is a matter or rerouting your hoses from where your cooling lines enter to radiator to your cooler... As I recall it is the top line I pulled to feed the cooler and the return from the cooler connects back to the fitting you pulled loose at the top of the radiator...
top cooling line---- cooler ---- radiator---- trans---- top cooling line
The flow is reverse it actually flows through the radiator first...
Mo
Old Feb 16, 2005 | 01:52 PM
cprgmr's Avatar
cprgmr
I have the B&M supercooler. I ended up having to get some supplemental hose from NAPA, but overall, it was a piece of cake to install. And yes, it's a very good idea to preserve the life of your tranny!
Old Feb 16, 2005 | 06:32 PM
Mo_Bandy's Avatar
Mo_Bandy
Darkman,
you have email, I frew it out for you... It is very easy, maybe an hour, just make sure the hoses you get are fro a auto transmission as it does have some pressure behind it...
Mo
Old Feb 16, 2005 | 06:40 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Originally Posted by Mo_Bandy
Darkman,
Mo
Hey Mo... would you mind sending that my way too? Would sure appreciate!
Old Feb 16, 2005 | 06:47 PM
Mo_Bandy's Avatar
Mo_Bandy
I'll do it now...
Mo
To How do I install a trans cooler?
