I have a 90 vette, was out for a ride yesterday and the second time i stopped at a location and shut off the car i noticed the blower motor (inside the car ((heat/ac))) was stuck on high, turned the ignition back on and played with the fan selects (1,2,3, etc) and it remained on high, even with the key off and out of the ignition the blower remains running on high, the only way i was able to get it to turn off was to pop the hood and pull the 4 terminal wire plug off of the blower box.... what could be the problem, the part that confuses me is that it is still on even with the car off and the key out ???? please help me !!!
i will try that.... where exactly is it located ? anyone know, i havent yet consulted my owners manual and i am still waiting for my service manual to arrive.
ok so i bought the new relay but cant for the life of me locate it, i was all around the blower motor, under the car, on top of the car, im going nuts here please help.... 1990 vette
I am having the same problem with the auto hvac in my 91. the blower stays on constantly. I checked the fuse (5 amp) under the coolant tank on the firewall and it was good. Is there another fuse? Could my blower motor switch have gone bad?
the busted part was the 'blower control module', 3 bolts hold it to the top of the air box, 2 are two wire quick connects on the top of it and the bottom is a large heat sink... i found it for $40 at an online vette salvage.... dealer wanted $150
