Cams and drivablility
Duration @.050 242/252 lift .56x/.56x w/1.6RR's on a 110CL
This is a hydrolic cam that has been tested at a GM tester that built my engine and said it has amazing results...we'll see in about two weeks!
Add advertised durations (at .004") for int & exh, divide by 4 and subtract the LSA to get overlap.
Using the ZZ9 cam for example (I happen to have the numbers for it):
advertised durations are 282/287=int/exh; LSA is 112. So,
overlap == (282 + 287 ) / 4 - 112 = 569/4 - 112 = 142-112 = 35deg.
Stick with the GM 846 or CC 305. I was at 363rwhp with the LT4 HOTCam. I expect to be close to 375-380 with my 846 cam when I get some dyno time in a few weeks. 1/4 mile times? I don't care...I road race.
If the car is 90% street driven and the engine is going to remain a 350, then you better be prepared for a rough idle and a loss in low end torque. If the car is a 6 speed be prepared for cam surge right at the typical cruising rpms. If you have an auto, you'll need a different torque converter (2800 or 3200 stall) for street manners.
In addition to the above, it'll need custom tuning just to get the power numbers the cams are capable of. If you're a perfectionist, be prepared for a lot of frustration if you have to have someone else tune it for you. Some of the above can be tuned out (to some extent). Unfortunately, it just means more time, more $$, and more frustration.
Of course all the above is pointless without a decent set of cylinder heads, the correct valvetrain, and a different exhaust since the cam will be inhaling and exhaling thru proverbial soda straws.
