I have an 90 A4 and want alittle more go than what I have now. I have on order a set of tpis Lt headers but I also want to get a better cam. I am trying to get opinions on the type and size of a good cam. I know I also will need to get better valve springs so I am thinking lt4 springs. Will these work for my set up?
BTW the car already has 1.6.1 rr and true deul exhaust.
Reportedly the stock #113 heads will flow to around 350chp and you can get there with the stock cam, so you may not get the full advantage of a cam change till you port the heads.
Anyway, the TPIS ZZ9 is a great cam for your car; maybe the LPE 219 would be good with worked heads.
Do you have the stock intake?
If I can acheive 350 with stock cam what other mod can I do without doing an cam change. Maybe SR intake and if I went this direction how much would this cost.
ZZ9 or Accel/LPE 211 would probably work best with the stock intake setup.
You would want to wait until after you pick the cam, to pick the springs. You want a matched combination.
I love my ZZ9 cam. I bought the matching springs from TPIS and used those. I also have the long tube tpis headers, ramdom tech cat and borlas. The kids come out of the woodwork every time I pull in somewhere. It sounds mean and runs great for an L98
What mods do you now have; do you have 2.59 gears??
To install a cam with eninge in the car it's necessary to remove all the front components and tilt the engine a little so the cam will clea the cross-member.
