best header tube size??
Old Feb 19, 2005 | 01:25 AM
lt4dogman's Avatar
lt4dogman
Default best header tube size??
Hi Guys
I know this has been kicked around here many times before, but I couldn't find it.
What is the best header tube size for on a 350 c.i. engine? Seems like there was something about if the tube size was too big ( 1 3/4" ?), you could lose power.
thanks in advance
Old Feb 19, 2005 | 08:33 AM
Nathan Plemons's Avatar
Nathan Plemons
There is no simple answer to this question. Some people will tell you that 1 5/8" makes more low end power than 1 3/4" Personally I don't buy it. I've seen too many cars gain horsepower by going up in header size.
I've seen an LS1 gain torque all the way across the board by going from 1 3/4 to 1 7/8. If it did that then you know 1 5/8 would have cost it even more. Now a chassis dyno graph starts around 2000 RPM, so there may be some difference below that point, but believe me it's negligable.
Ultimately there is no blanket answer. If your engine only turns 5000 RPM's and you're running stock heads, yeah 1 5/8 headers might be OK. If you're turnning 6500 RPM's with a cam and good flowing heads then you'll probably really want the 1 3/4"s This is because what you gain on the top end may outweigh anything that you give up on the bottom end.
I hate to say it but go over to the f-body forums and take a look at the power that people are making on stock head cars with just cams and headers. They're all running 1 3/4. The 1 5/8 is better for low end torque thing seems to be common only to this forum. Every big HP car I've ever personally seen has 1 3/4 or larger.
Old Feb 19, 2005 | 10:19 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
maybe people need the smaller diameter for backpressure if they're running open headers or straight pipes or maybe people spent $$ on smaller headers and don't want to admit they could be losing hp
Old Feb 19, 2005 | 10:44 AM
Red Tornado's Avatar
Red Tornado
....The 1 5/8 is better for low end torque thing seems to be common only to this forum....
That's generated by one or two folks and repeated over & over by a few others. If your 350 cid is generating about 375chp, then 1.75" is definitely recommended. So says David Vizard.
Also key is flow at the exhaust ports of your heads. Here's a formula for kicks, assuming you've got ported/good aftermarket heads:
Recommended primary diameter = The square root of: exhaust cfm at max valve lift X 1.27, then divided by a factor of 85.
Fun, eh? This is mathematical theory. Nathan tells it outright. But the whole gig is that if you've got extra ponies under the hood (heads, cam, exhaust.....and intake for the L98 guys), then for all intents & purposes get yourself a set of 1 3/4" headers........Sure 1 5/8" is great for an all stock C4 engine BUT if you have inkling that you'll be modifying it in the future, save yourself the agony of wasted $$ having to buy another set of headers (hey thats $600-$700 after full coating).....You'll definitely get SOTP bang now and it will increase even greater, later.
Ok my little sermon is over
P.S. I re-read the original post. You have an LT4, which is only inches away from the 1 5/8" vs. 1 3/4" line in full stock trim. If I were you, I wouldn't hesitate for a second in getting 1 3/4".
Now the sermon is really over
Old Feb 19, 2005 | 11:10 AM
cv67's Avatar
cv67
St. Jude Donor '05
I've always stuck to 1 5/8 if its a sreet car for all-around torque; If it was a mostly strip/some track/track only, and had the cam, gears and heads to justify it, then 1 3/4 may be your answer. Depends on the car.
Which year motor/mods? Auto/Stick, gears? Maybe that would help
Edit:Seems you have the LT4-
Old Feb 19, 2005 | 11:21 AM
vader86's Avatar
vader86
1.75" for me
Old Feb 19, 2005 | 12:08 PM
CFI-EFI's Avatar
CFI-EFI
I am one of the bigger advocates of the 1 5/8ths" headers. *I* don't even HAVE headers on my car, so that quote certainly doesn't apply to me. I think that is true of many of the guys with 1 3/4" headers. They've spent their money, received a gain, and they don't want to consider that they could have made a better decision.
The smaller tubes will start to work at lower rpms. They will boost low speed power where the 1 3/4" won't. For any normally street driven 400 CID or smaller gen I or Gen II SBC, the 1 5/8ths" tubes will give up no power on the top end. I agree with the comment, above, concerning the header sizes on the LS engines. Those Gen III and Gen IV engines are a totally different animal than we C4 owners deal with. You will get a good gain with 1 3/4" headers. However, you will get a greater gain, over a wider rpm range, with 1 5/8ths" headers. If you aren't convinced by the rantings of a guy that doesn't even have headers, look up Jesse and Corkie, with their 10 second 434s and ask THEM what big headers did for them, and at what engine size. If you drive it at all, you want the smaller tubes. If you only race it, you want to look very closely at your set up, even so 1 5/8ths" will be the right choice for a 350.
RACE ON!!!
Old Feb 19, 2005 | 12:56 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I ain't got no dog in this fight, I've decided to be like Switzerland. Can't we all just get along?
Old Feb 19, 2005 | 01:28 PM
redcorvettedave's Avatar
redcorvettedave
RACE ON!!!
MY MAN .....WHEN IT COMES TO HEADERS
OH SNAPS!!! NATHANS MY MAN WHHEN IT COMES TO LT1'S
Old Feb 19, 2005 | 01:39 PM
Nathan Plemons
And their cam choice and head numbers and desired RPM of operation all play major roles in that. They built their engines for torque, if they shift at 5000 RPM's every time out how would they know if they gained 50 horsepower at 6000 RPM's?
The best answer to this question is simple. Buy whatever the hell damn header you want and then keep your opinion to yourself because lord help you if your opinion differs from somebody else.
Old Feb 19, 2005 | 01:47 PM
Red Tornado
CFI-EFI, with all due respect to those who make a hobby out of it, I'm apt to subscribe to folks like David Vizard who's made it their 24-7 business to learn from a lifetime of research and engine development. And yeah, we're talking Gen I and II engines. When he says 375 gross hp with decent heads for 1.75" headers, then I'll take that to the bank.
See my post above.
Old Feb 19, 2005 | 02:03 PM
Pete K's Avatar
Pete K
Old Feb 19, 2005 | 02:11 PM
Red Tornado
JackDidley's Avatar
JackDidley
I laugh my butt off every time this debate comes up. Great entertainment on a cold winter day.
Old Feb 19, 2005 | 02:45 PM
redbullapril23's Avatar
redbullapril23
i will soon get 1.75s
Nathan is the man.
knows his stuff
thanks for the try guy
Old Feb 19, 2005 | 02:54 PM
Corvette Kid
Yeah, I'm getting too old and tired to fight. Since there are really no suitable 1 5/8" headers for my LT1, it became a moot point anyway for me. I'm just glad to have a set of EMs AND a set of DRMs sitting here and trying to decide which set to use. That's a GREAT problem to have....
Old Feb 19, 2005 | 04:42 PM
CFI-EFI's Avatar
CFI-EFI
Do you really think those low 10 second cars (Jesse's and Corkie's) are being shifted at 5000 rpms? When you ask them about header sizes, ask about heads, cams, manifolds, and shift points, too.
The originator of this thread ASKED for input on header tube size. Are you telling me NOT to share my years of experience in what works, and where, to those that ask??? Are the facts so intimidating??? You like many others have committed to a choice and some can't stand the thought that there might have been a BETTER choice.
"...then keep your opinion to yourself because lord help you if your opinion differs from somebody else." I see you have failed to follow your own advice.
RACE ON!!!
To best header tube size??
Old Feb 19, 2005 | 06:06 PM
Nathan Plemons
Look, I gave my input, you gave yours. Now I advised the person to take his information and make his decision and then don't even bother letting anybody know what it is because SOMEBODY will tell him he made the wrong choice.
I'm not going to argue with you because it's not worth it. You're so convinced that you're right that you won't listen to any other points and likewise so am I. It's a waste of time to debate it any further.
Is that OK with you?
Old Feb 19, 2005 | 06:49 PM
Corvette Kid
Default To Nathan & CFI-EFI
It's common knowledge to anyone who's been on the forum for any time at all that this subject has been discussed ad nauseum. I'm not complaining because repetitive posts generally don't annoy me much. I just don't click on them. But I'll admit I always have to check this one out just because in all my years of messing with cars this has always been a topic of debate. And I'm never certainly too old to learn. That being said, I truly hope that you two will continue to respect each other and agree to disagree. You're both two of the people on this forum who's posts or threads I almost always check out, regardless of subject matter because I respect your thoughts and opinions that much. Although a lot of it has been in the parts for sale section, there's been a seemingly inordinate amount of bickering on the forum lately and I hope that two guys I've never met but consider friends won't hold a grudge over a disagreement on theory. This place is my internet family so this really matters to me.
Old Feb 19, 2005 | 08:25 PM
CFI-EFI's Avatar
CFI-EFI
That's OK with me.
Maybe I misinterpreted this paragraph as being directed at me:
I can agree to disagree.
RACE ON!!!
