safest way to do N02
Old Feb 19, 2005 | 02:40 PM
redbullapril23's Avatar
redbullapril23
Default safest way to do N02
ok let me know what you think.
I have a 1996 autl lt1 stock internals 80k on the clock.
I have LT headers, 52 mm tb, no cats or mufflers, under drive pullies..all the bolt ons.
what would be the safestes way for me to add a little N02 my ride?
I will soon install 3.31s and also a cam.
I just dont wanna throw a rod with too much compression.
what are your thoughts? and $ for what you recomend.
not sayin I am 100% for sure going to do this...but Id like more info.
thanks alot your friend
Sean
Old Feb 19, 2005 | 09:02 PM
Bruce's Avatar
Bruce
Generally a well setup with 100hp is pretty safe but no body can garrantee you won't ruin your engine. The basic kit you see for sale $499 that is not include with every safety features. A well setup can you over $1000. Few yrs a go I paid for my NX kit with every safety features that cost $886, on top of that I have to get a upgrade fuel pump, N2O/fuel pressure gauage, pillar, MSD box with single stage for nitrous retard. all this goodies can add up over $1000.
ps. nitrous like high compression. Forced induction like low compression. Your connecting rod is not a problem with nitrous but your factory piston will have a problem if you are getting detonation.
Bruce
Old Feb 20, 2005 | 01:45 AM
redbullapril23
kool
thanks
is there any way to bring it on gradually or always run with it on a little?
Old Feb 20, 2005 | 04:45 AM
zelement's Avatar
zelement
Originally Posted by redbullapril23
kool
thanks
why are you going with 3.31 gears?
the nx maximizer will allow you to bring out the nitrous based on a percentage and time.
For example you can start it at 30% and gradually build it up to 100% within 2secs. The maximizer is a very nice piece of equipment to have.
Old Feb 20, 2005 | 07:20 AM
redbullapril23
yes i would like that!
how much would a kit like that wiht purge and maximizer cost?
i am going with 3.31s as i have stock 2.59s and Im afraid to go with anything to low in the dana 36! the 3.31s are also only like $170
your friend
Sean
Old Feb 20, 2005 | 09:46 PM
zelement's Avatar
zelement
your friend
Sean
Purge is cheap, all you need to do is find a nitrous solenoid and plumbing to shoot it outside.
Maximzier is around 500.
Old Feb 20, 2005 | 11:25 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Are you going to the track or just street?
A barry Grant system will give you the most bower for the buck.
100 shot will bring you into the 12's.
You will need some good DR Nitto or MT Street.
That rear end will work but the mile P H will be high.
The 20000169 fuel pump from worlb will be the best.
You will need to change your plugs to BP8EFS NGK.
You will need to run 106 nitrous racing fuel and install a LT4 Knock sensor only about $40.00.
All the bells and whistles you can install but I would just hit the switch as you want when going down the track.
Old Feb 21, 2005 | 04:39 PM
redbullapril23
got ya!
well i am already in the 12s
about 12.7
good info!
1. ok well hmm if got the purge valve, lt4 knock sensors, and no maximizer
would I be good to go?
itll be on the street and see the ocasionaly drag slip use!
2. also do i have to run race gas? thats expensive. i always use premium...thats a given...
3. how hard is it to install one of these kits? do i have to tune the AFR etc?
Sean
Old Feb 22, 2005 | 01:36 AM
REDC4CORVETTE
If you use a 100 shot you don't need to do anything.
The 100 shot will take a second off your 1/4 time!
If you don't get a full second something is wrong, I use the B8EFS NGK plugs.
MSD 6AL box ,HYPERTECH power programmer.
YOU realy need one of these is you are going to run nitrous.
I removed the revlimiter from the computer that is a must to run nitrous on an LT1/4.
I short the trans shift point1-2 300 rpm's and the 2-3 shift 200 rpm's.
I use the 160 stat no nitrous above 200 degrees or it will lean out to much.
I use a retard but not necessary with only 100 shot.
Next stop 11.70 at over 120 mph.
Yes it is that easy.
You could go faster but I don't turn mine on until 2nd gearor just after I get moving out of the hole.
I run 11.20's but I also use tunercats and datamaster to moniter the engine and I run a lap top on the pass seat.
The ASR/ABS kicks in when doing a burn out if you don't keep the car centered when burning out,also retards the engine 15 deg so only burn out once and don't bounce the car on a second burn out.
Old Feb 22, 2005 | 03:08 PM
redbullapril23
ok I have the hypertech...
can yall give me the links where to buy:
1.the plugs
2. MSD box
3. N02 kit you recommend
4. any other hardware Ill need (purge line).
thanks alot
that sounds like a very good set up!
your friend
Sean
Old Feb 24, 2005 | 02:41 AM
REDC4CORVETTE
http://www.barrygrant.com
You want the 75 to 175 It's on the site if you look hard.
The purge I would get from NX theirs is better,barry grant purge sucks.
Don't buy the NX kit I have one of each and the barry grant is better ,the tech support is better with NX.I still like the barry grant unit.
Jegs for the 6AL $195.00 and you will need the pigtail for the coil hook up,I don't like cutting up my car so I spend the extra money.
The plugs are just NGK B8EFS they are 2 steps colder NAPA or any auto store.
If you decide to run a fuel presure regulator,only use the Aeromotive unit all the other regulators will fill your motor with fuel and lock it up .Been their done that.
The number 8 plug is the hardest to get to .
If you buy a snap-on 5/8 swivel spark plug socket it works great with the long off set handel on the 3/8 racket.
A piece of vacuum hose on the end of the plug will make it easy to install the plugs.
Watch out for that bolt on the oil dip stick it smarts.
Old Feb 27, 2005 | 10:19 PM
gotn2o?'s Avatar
gotn2o?
you could also take a look here:
http://www.holley.com/HiOctn/ProdLin...NOSNS/GM1.html
http://www.holley.com/HiOctn/ProdLin.../LS1NOSzle.htm
Old Feb 28, 2005 | 02:40 AM
REDC4CORVETTE
I would not run a NOS system on a late model car.
Neather of the systems in the link will work for your 96.
Old Mar 1, 2005 | 11:56 AM
gotn2o?'s Avatar
gotn2o?
I believe the 05151NOS will work with a 96 LT1. I think if you use it on a LT1, you need to modify the accelerator, kick down, and cruise control cable bracket.
It depends on if you want to hassle with it. I'm sure the NOS techs would talk you through it though.
Old Mar 1, 2005 | 09:00 PM
M.Clough's Avatar
M.Clough
neither one of those will work but nos does sell a single nozzel kit 599.00 or the offer a kit for the lt1.I would highly recomend the holley nos line they have been doing longer then all of thier competion combined.I have severl customers running 125 hp on nos on lt1 camaros and all they have is an msd 6a box, better wires,and colder plugs.You should be able to run a 100 shot all day long and not hurt anything.buy the way remove the hypertech power programer.Any device that makes power buy advancing ingnition timing and nytrous will not mix( a quote right from hypertechs tech line)
Old Mar 2, 2005 | 12:19 AM
gotn2o?'s Avatar
gotn2o?
This one's a "dry" system:
http://www.holley.com/HiOctn/ProdLin...NOSNS/GM2.html
Old Mar 3, 2005 | 01:05 AM
REDC4CORVETTE
You said you changed the cam I hope the off set is 112,or you could have a problem.
To safest way to do N02
Old Mar 3, 2005 | 07:04 PM
1kwikvette's Avatar
1kwikvette
Redbull,
I have a Dana 36 in my Vette with a 383 pushing 400Tq to the ground w/o NOS and I have 3.73's in it for two years now, no problems whatsoever. Just FYI.
Old Mar 3, 2005 | 08:21 PM
cprgmr's Avatar
cprgmr
Originally Posted by 1kwikvette
Redbull,
At least go 3.45's. The 3.45's are said to be the "perfect" gear for the Vette. I'm running 3.54's in my D36 and havn't had one problem (knock-on-wood)...
Old Mar 4, 2005 | 12:55 AM
redbullapril23
im gonna go 3.31s...
most cost efficient way...
