Meziere - Quality None
Old Feb 20, 2005 | 11:23 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Meziere - Quality?? Rant
Just a rant - New Meziere WP301 electric water pump has anti-freeze leaking out the rear of the pump.
Thank goodness a friend of mine lent me a coolant system tester. At 17 pounds of pressure the pump leaks. I know that sh*t happens - but why me. Now the engine start-up has to wait
Corkvette and I took the pump off and checked all bolts for tight - reinstalled and it still leaks.
Looks like I have to call tech and complain a bit - I only have a month to get my beast running.
Old Feb 20, 2005 | 11:40 PM
bogus's Avatar
bogus
ugh.
Old Feb 21, 2005 | 03:44 AM
ClarenceT's Avatar
ClarenceT
At least you didn't buy it from a chain store, because then when you go back, they'd test it, and tell you that you have no clue what you're doing because the expensive water simulator machine said the pump is fine
Old Feb 21, 2005 | 06:36 AM
85vet's Avatar
85vet
Cruise-In V Veteran
I hear that, but I still have an urge to shake/strangle somebody
Old Feb 21, 2005 | 06:46 AM
Nathan Plemons's Avatar
Nathan Plemons
**** happens with any company. The difference is in how they handle it. Meziere is a stand up company they'll make it right.
Old Feb 21, 2005 | 07:39 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I've heard the same.
Old Feb 21, 2005 | 09:25 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
good luck to you on this. Please keep us posted on how this turns out as I am planning on doing the Meziere when I do my cam.
Old Feb 21, 2005 | 10:24 AM
VAHROOM's Avatar
VAHROOM
If you still have that urge, the house next door to me has a NOISY party just about every Friday night.
Bummer on the pump but at least you weren't on a long cuise when you found out.
Old Feb 21, 2005 | 11:25 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Sent an email racepartsolutions.com early this morning and we have emailed back and forth at least twice to see about getting this resolved. I do not expect any problems - I just had to rant.
PS - check out their prices on pumps - if not listed email and he will get back to you. They beat Summit by +20 and it was drop shipped immediately. I went with black and originally summit said it would take weeks to receive before I canceled and went with racepartsolutions.
Kwik_TA - besides modifying the alternator and A/C brackets to to fit the new water pump - We (Corkvette1 and I ) ok, Corkvette1 recommends buying some gasket material and make new gaskets without the lower bypass holes and use plenty of sealer. The new pump has less material to seal below and around the bypass holes. Our first install had water pouring out of the passenger side bypass hole before pressure was ever applied.
Old Feb 21, 2005 | 01:20 PM
Perfusion's Avatar
Perfusion
Sorry to hear about this... I'll tell ya', though, that's the #1 reason that I just stick with GM stuff on parts like that - it's just not worth the risk of a headache over a few HP.
Old Feb 21, 2005 | 01:35 PM
mitchcole's Avatar
mitchcole
uh-oh...I just put one in...
Old Feb 21, 2005 | 02:03 PM
Nathan Plemons
Don't worry, your LT1 meziere is a little more straightforward that what he's dealing with.
Old Feb 21, 2005 | 05:25 PM
1996man's Avatar
1996man
thats good to know. i plan on ordering one for my LT4 here soon when i do my cam swap
Old Feb 21, 2005 | 05:51 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Mine's been performing flawlessly for over 10K miles now.
Old Feb 21, 2005 | 07:07 PM
kopbet89c4's Avatar
kopbet89c4
I laughed so hard about that comment I spit my drink on the screen.
Lots of shops around probably do about the same crooked business here.
I was thinking about getting an electric water pump but this thread made me decide against it .
To Meziere - Quality None
