Vortech FMU question
If it is the super FMU, I have one by the way I'll sell you...
The screw adjustment is a bleed off screw that limits tha max fuel pressure.
Here is a link on it...
http://www.vortechsuperchargers.com/...superfmuim.pdf
Hope this helps,
Mo
BTW, I think I found my leak. I think it's the power steering hose. The fluid looks similar to oil and my power steering unit was almost out of fluid after the drive out to your place. I since topped it off and in 5 miles of driving, it was down an inch....
that's correct
From: "Riggs, Russell" <RussellRiggs@BristolWest.com>
Sent: Thursday, February 24, 2005 12:23 PM
To: mancheta@vortechsuperchargers.com
Subject: RE: fmu bleed off valve
Thanks for the input valve. So it does reduce the fuel pressure step up ratio when the thing is unscrewed outward? Thanks!!
Russell Riggs , LPCS
Claims Representative for
Coast National Insurance Co.
PO Box 61007
Anaheim, CA 92803-6107
800-541-4153 ext. 2329
-----Original Message-----
From: Mike Ancheta [mailto:mancheta@vortechsuperchargers.com]
Sent: Thursday, February 24, 2005 11:03 AM
To: Riggs, Russell
Subject: re: fmu bleed off valve
yes, that is a bleed off valve for the fmu....
Sent: Wednesday, February 23, 2005 12:53 PM
Subject: fmu bleed off valve
I’m not sure that it’s called a bleed off valve or if there’s a proper name for the part opposite the input hose. Can you verify what it is and let me know exactly what it does? I am not sure if it adjusts the base fuel pressure or if it drops the step up ratio under boost.
Thanks!
