motor mounts
Old Feb 21, 2005 | 07:23 PM
squalsvette's Avatar
squalsvette
Default motor mounts
hey fellas.......i have a 95 vert six speed........lately when i first start my car sounds like the muffler is no hitting the floor boards on passenger side, nothing extreme........and it only does it when i first start the car, and sometimes when i back out of my driveway, but not all the time.........motor mount?.....anyway i can tell , can't see anything in there......and if so how bad is it to still drive around?........thanx guys
Old Feb 21, 2005 | 07:55 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
did you put the car up to take a look underneath? i would give the exhaust a shake to see if it is indeed loose (or if there is anything else loose under there).
you might want to have someone give the throttle a stomp while you carefully look at (and listen to) the engine.
Old Feb 21, 2005 | 11:32 PM
87NassauBlue's Avatar
87NassauBlue
If it's a convertible, you exhaust may be getting on your Xbrace
To motor mounts
