6 speed question
Old Feb 21, 2005 | 07:38 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Default 6 speed question
Went to drive the Vette this weekend and had barley any clutch pedal pressure, the next day it had none and wont go in gaer. Any thoughts on the problem??
Old Feb 21, 2005 | 07:47 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
did you check the clutch master cylinder fluid level? is there any fluid leaking from either the slave or master cylinder? definitely sounds like a hydraulic problem.
Old Feb 21, 2005 | 08:20 PM
FELNGR8's Avatar
FELNGR8
You have a leaking clutch slave cylinder like a lot of us. Right now you can just refill the reservoir and pump it a few times to get back under way. The reservoir is under the computer.
The master cylinder reservoir won't take very much fluid so you will need to recheck it regularly. If it goes down rapidly ( needs refilling before summer) you will need the slave replaced.
Old Feb 21, 2005 | 08:33 PM
TOO_HOTTVETTE
Thanks guys, I haven't checked the fluid level doh! I'll try that first and go from there. Does it use the same fluid as the brake system?
Old Feb 21, 2005 | 08:43 PM
FELNGR8's Avatar
FELNGR8
Yes, it's brake fluid.
Old Feb 21, 2005 | 09:04 PM
tempest's Avatar
tempest
the GM fluid has some antisqueak lube in it but it is indeed basically brake fluid. i use Valvoline DOT3/4 (Synpower?) in mine.
To 6 speed question
