Optispark drive shaft seals
Old Feb 21, 2005 | 11:24 PM
zrwon_Can.'s Avatar
zrwon_Can.
Default Optispark drive shaft seals
Hi, I just bought a new Optispark, removed the old one and noticed the new one doesn't have the o'ring on the drive shaft??
Aren't they suppose to come with new o'ring?
The old ones are 10 years old already, I don't think I should reuse them.
If I should get new one and if they don't come with the new unit, what is the P/N and are they easy to find?
Al
Edmonton, AB
Old Feb 21, 2005 | 11:39 PM
bogus's Avatar
bogus
an o-ring on the drive shaft? I don't remember one on my 92...
IF you feel the need, any o-ring will do.
Old Feb 21, 2005 | 11:45 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
could be this... 10474278,OptiSpark O-rings
Found here
http://impalassforum.com/cgi-bin/ult...;f=33;t=001279
Old Feb 21, 2005 | 11:49 PM
ConeKLR's Avatar
ConeKLR
My lt4 opti has two on the optispark shaft that goes into the timing cover. My new opti did not come with them. The two orings on my old opti were dried up, one broken in many pieces. You may be able to get away with using orings from a hardware store. Not sure if it calls for orings that are oil resistant.
Old Feb 21, 2005 | 11:53 PM
belmor's Avatar
belmor
I am doing mine this weekend, i will have to look and make sure they are ok when it goes back together
~B~
Old Feb 22, 2005 | 12:12 AM
zrwon_Can.'s Avatar
zrwon_Can.
Found here
Thanks so much Steve, I bet this is it since P/N 12552428 is the Front cover Optispark Seal, this has to be the o'ring then.
Al
Old Feb 22, 2005 | 12:19 AM
bogus's Avatar
bogus
black o-rings would work fine. Oil proof is not the same as fuel proof. fuel proof are normally brown...
I would to to either a good parts shop or a good hardware store.
To Optispark drive shaft seals
