Have to replace both rear bearings?
Old Feb 22, 2005 | 09:15 AM
V's Vette's Avatar
V's Vette
Default Have to replace both rear bearings?
Just making sure here -- I know I have to replace my left rear wheel hub. But, the right one is tight. Can I wait on the right, or do I replace it at the same time as the left?
Old Feb 22, 2005 | 09:24 AM
Pete K's Avatar
Pete K
You can change 1. Just expect the other one to be close behind. Will not hurt anything though.
Old Feb 22, 2005 | 09:28 AM
Nathan Plemons's Avatar
Nathan Plemons
You should be OK to replace just one.
Old Feb 22, 2005 | 10:28 AM
1989redvette's Avatar
1989redvette
i did my left one 3 years ago and have had no problems with the right at all..save your money and spend it on something else
Old Feb 22, 2005 | 07:37 PM
TrackDayLT4's Avatar
TrackDayLT4
If it ain't broke don't fix it!
Cheers,
Lawrence
Old Feb 22, 2005 | 07:43 PM
aboatguy's Avatar
aboatguy
Wheel bearings may fail in a year or like the Energizer Bunny keep going and going. Save your money and just replace the failing bearing.
Good luck.
Mike
Old Feb 24, 2005 | 06:12 PM
V's Vette's Avatar
V's Vette
Thanks to all! I've ordered the Hub for the left from Autozone, and will keep an eye on the right rear.
To Have to replace both rear bearings?
