Crossfire to carburetor
Old Feb 22, 2005 | 11:29 PM
Atarii's Avatar
Atarii
Cruising
Default Crossfire to carburetor
Has anyone out there converted their '84 from FI to carburetor? I've inherited a basket case and have several questions about wiring and the computer. Thanks.
Old Feb 22, 2005 | 11:41 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Ask your questions and we will see if we can help.
Old Feb 22, 2005 | 11:54 PM
Atarii's Avatar
Atarii
Cruising
Where do I start.... Does the computer do anything anymore? The distributor has been replaced with one that doesn't have a plug to communicate with the computer. So, the fuel pump relay doesn't work or the cooling fan relay (just to name a few). I've wired the fuel pump relay to the ignition power wire. Now, the pump runs all the time when the key is on. I'm trying to figure out what to do about the cooling fan relay- it's not getting power from the computer to turn on the fan. Also, the cruise control servo is gone. Is it not possible to have cruise with the carburetor? I have a plug hanging out near the computer on the passenger side of the center console with 4 wires- pink/black, pink, black and orange. I don't know what plugs into it- it looks like it should be some kind of relay. Unfortunately, so many things have been unplugged or removed, I'm having a hard time figuring out what's what. This is just the beginning.... Thanks in advance.
Old Feb 23, 2005 | 12:54 AM
Rich & Lisa_84
The only thing my computer does is run the Digi Dash.
The cooling fan relay should be lookig for a ground. Mine gets this from a temp switch located between the 6 - 8 cylinders. You can pulls this wire and attach it to ground and then the fan should run when the key is on.
I don't think so.
I will have to check and see what this goes to, I don't know off the top of my head.
Do you have the car running yet. Other than the Intake, Carb and Distributor, did they do any other chages that you know of.
Old Feb 23, 2005 | 08:37 AM
Atarii's Avatar
Atarii
Cruising
Unfortunately, the dash isn't working either. I did some resoldering on it, and now it comes one, but it doesn't work. Do you recommend anyone to rebuild it? The fan works, but somebody cut the black/red wire to the fan and put a jumper on it for power. I've replaced the relay. As far as I can tell, there are no other modifications. I've just got the car running, but it's running pretty rough. It has a Holley 4-barrell- is that okay for this car? Any suggestions on initial adjustments? How did you wire your fuel pump relay? Does the carb increase horsepower over the fuel injection?
Old Feb 23, 2005 | 10:47 AM
rick lambert's Avatar
rick lambert
Go to the bottom of this page-where it says pages 1-900 or something, start checking, there was quite a discussion about this within the last week or two.
Holley is a great carb. putting the right size on is the key (I think 650cfm is probably right) depending on any other mods you intend.Some people will say you'll lose MPG, ease of starting etc. and for every day driving and going back in time- their most likely right.But if you'll notice-most all the monsters are running carbs.
Rich and Lisa and others on the forum have done this.So their probably your best sources.
Old Feb 23, 2005 | 11:08 AM
CFI-EFI's Avatar
CFI-EFI
Just to elaborate, slightly, the ECM is not involved in the fan operation, on an '84.
RACE ON!!!
Old Feb 23, 2005 | 11:33 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Try Crossfire Forum
www.crossfire.webhop.net
Plenty more info you require.
Good Luck.
Old Feb 23, 2005 | 11:38 AM
Atarii's Avatar
Atarii
Cruising
Thanks all- you're right- I misunderstood the book. I'll have to rewire the relay and then see what I've got. I'm not too impressed with this haynes manual....
Old Feb 23, 2005 | 11:48 AM
CFI-EFI's Avatar
CFI-EFI
Which relay? Although the carb conversion negates a lot of it's value, the Factory Service Manual, will at least help you understand how it DID work and provide you with a complete wiring diagram for the whole car.
Also, the computer controlled the TCC. You will have to be sure that has been provided for.
RACE ON!!!
Old Feb 23, 2005 | 12:14 PM
Atarii's Avatar
Atarii
Cruising
I'll have to get the manual- right now I'm working off of wiring diagrams from shopkey. I have no idea if the TCC solenoid has been rewired. What inputs does the computer need to control the TCC?
Old Feb 23, 2005 | 12:52 PM
Rich & Lisa_84
I sent you links to the Manuals. Enjoy.
Old Feb 23, 2005 | 01:47 PM
CFI-EFI's Avatar
CFI-EFI
I can't say for a fact, but it seems logical that the TPS, MAP, VSS, and rpms (pulses from the distributor), would all be a part of it.
RACE ON!!!
Old Feb 23, 2005 | 02:56 PM
Atarii's Avatar
Atarii
Cruising
Thanks! Got the cooling fan working!
Old Feb 23, 2005 | 03:04 PM
4bblC4's Avatar
4bblC4
the comp controls the digi dash.... hmmm......
oops.
Old Feb 23, 2005 | 03:07 PM
ben73's Avatar
ben73
RACE ON!!!
Nor is it required for the digi-dash to operate. The only signal that comes from the ECM to the dash is the MPG display, and that won't work once you have a carb anyway.
Old Feb 23, 2005 | 03:45 PM
Atarii's Avatar
Atarii
Cruising
What should the fuel pressure run? 7-9 psi? It's at 4 now, probably why it's running like crap.
To Crossfire to carburetor
Old Feb 23, 2005 | 03:51 PM
Rich & Lisa_84
Fuel pressure should be around 7psi +/- 2 psi depending on carb.
When I disconnected my ECM, My dash went blank. When I reconnected it, everything came back on.
Old Feb 23, 2005 | 03:57 PM
FD2BLK's Avatar
FD2BLK
Ok I did this conversion and there is a lot of misinformation out there. The only function the ECM will have is to run the FP and the TCC lock up both of witch can be done without it. If the Fuel pump isn't running jumper the ALDL and it will run (I THink its pin G but I am out of the country and cant check. As far as the TCC lock up there is no engine data needed on the 84 just the trany and brakes are used. THe ECM has no efect on the dash, I ran my 84 w/o a ECM for a year. If you get a lock up kit and wire the FP relay enable wire to ING 12V everything will work without the ECM and it can be removed. You still need the sensor wires and sensors Oil Temp. Oil presh, Temp, and Fan sw sending unit. You will need a FP regulator to set the FP aroung 6-8 PSI for the carb a T between the feed and return line with the regulatror on the return side works, Hope this helps as I am using dial up but will be back in the states next week. THe thing I did not know is that the ECM will still lock up the TC on the 84 as long as it has power ground and the trany wires, it would have saved me $80 that I spent oin the kit, Again the ECM has no effect on the dash other then MPG everything else is a sensor and it does not go through the ECM
Old Feb 23, 2005 | 04:07 PM
Rich & Lisa_84
Then when it warms up, I need to get under the dash again and find out what wiring has been changed by the guy before me. Because when I unplug the ECM, my dash goes blank. Thanks for the info.
