85 auto ignition timing specs and proceedure?
Old Feb 23, 2005 | 05:07 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
Default 85 auto ignition timing specs and est proceedure?
got no sticker on the radiator support and doing a search gave me squat, so i'll have to bother the experts.
my chilton's says look on the sticker for degrees, and it also says disconnect the est. do i have an est, and if i do, how the hell do i disconnect it at the distributor?
tanks, froggy
Old Feb 23, 2005 | 05:33 PM
mikenfl's Avatar
mikenfl
The stock setting is 6 degrees btdc. The connector in question is a single wire connector under the brake booster.
Old Feb 23, 2005 | 05:53 PM
Square's Avatar
Square
mikeinfl is correct!
Also, the wire on my 86' is black with a brown stripe. I believe this is standard.
HTH!
Old Feb 23, 2005 | 07:51 PM
CFI-EFI's Avatar
CFI-EFI
And the Factory Service Manual is available at www.helminc.com
RACE ON!!!
Old Feb 23, 2005 | 08:22 PM
mikenfl's Avatar
mikenfl
RACE ON!!!
I bought mine from MAM. Expensive, but worth it. Chilton's is compared to the factory manual.
Old Feb 23, 2005 | 08:37 PM
CFI-EFI's Avatar
CFI-EFI
What's a "MAM"? My link is to the publisher.
RACE ON!!!
Old Feb 23, 2005 | 08:38 PM
parafrog's Avatar
parafrog
thanks for the info.
i'm working on a getting a helms off ebay, but the problem is some people are willing to pay 65 bucks for a used one when a new one is only 80.
froggy
To 85 auto ignition timing specs and proceedure?
