Code Scanners
Old Feb 23, 2005 | 05:09 PM
Teh Nam's Avatar
Teh Nam
Default Code Scanners
I have a '95 LT1. I want to purchase a code scanner, do I need to get OBD1 or OBD2? Or a unit that is capable of both? Any suggestions on brand and model? Thanks!
Old Feb 23, 2005 | 10:33 PM
-js-'s Avatar
-js-
I believe 94 and 95 are obd1 with the obd2 style connector.
Check out these for a start.
http://www.andywhittaker.com/ecu/ecu_software.htm
http://www.techedge.com.au/vehicle/a.../160serial.htm
Old Feb 23, 2005 | 10:45 PM
Akela's Avatar
Akela
Cruising
Many vendors require that you select your vehicle make and model as part of the ordering process. This should greatly reduce your risk of getting the wrong scanner.
BTW, I believe the '95 would use an OBD-I scanner. Not sure about the connector. Suggest you check out -js-'s links.
Old Feb 24, 2005 | 12:30 AM
KayCee's Avatar
KayCee
OB1 guts and OB2 connector.
Old Feb 24, 2005 | 08:04 AM
runner140*'s Avatar
runner140*
Default I agree...
In 1995 it was a OB1 with a OB11 connector. 1996 was the first year that the OB11 went operational.
Old Feb 24, 2005 | 06:44 PM
Teh Nam's Avatar
Teh Nam
Cool, Thanks!
To Code Scanners
