What long term risks / damage is possible with leaky injectors??
Old May 16, 2005 | 07:46 PM
tjm2070's Avatar
tjm2070
Default injectors/pressure/smoke
1985 corvette stock stock 350 with K and N and no cat. (previous owner removed) so basically a stock car...
just want to make sure i ahve this right here...
which ones are plug and play?
was there a chance in 88 or so?
FMS 22 lbs. ?
and accel 21 lbs?
are the pink tops the FMS?
how high of hp are these good for
how high of flow can you go and have an 85 learn even in open loop / WOT ?
i want NO messing with fuel pressure or chips...
is there anything besides a leaky injector that can cause gas/rick smoke at startup?
also what is the range of fuel pressure at idle? i think im getting 38... (but i pulled the wrong vac tube so it jumped up but i bet it woudl jump more with the actual fuel vac tube pulled...
THANKS
Tj
