Thanks to all the people who have helped me in understanding what the heck the prior owner of my car has done to it! After looking it over, I think my problem is a worn cam. Ironically, it was his as well. I think he was throwing things at the engine looking for more power when the cam was worn all along. He put on a TPIS Big Mouth intake with siamesed runners and a larger throttle body. Add to that 3" exhaust and low restriction mufflers and 3.73 gears... The engine makes a lot of valve chatter/rattles. Sound like loose lifters, I am guessing that the cam is worn down... It does have 135,000 miles... What is a good cam setup for a late L98? I have gotten a couple of recommendations of a ZZ-9 cam or a Hotcam. They both sound good, are there any other items that need to be put in with a cam? Timing chain, lifters, rocker arms...? Thanks again!
I have and like the ZZ-9. Others like the hot cam. I'd say that the hot cam will probably be less expensive. Along with the cam you will need lifters and for sure a new timing gear set.
Plenty of good feedback on the zz9 cam here. What year is your vette?
