window switch wires
Old Feb 25, 2005 | 07:45 AM
notherc4's Avatar
notherc4
Default window switch wires
Need some help guys. I had my passenger door panel off last night and all was fine till I went to reinstall it and noticed that I knocked the 3 wires off in the bottom. There is 3 from up to down and 3 from left to right. I cant find the combination to make it work correctly. I thought I had it but when I went to use the master (drivers) switch it worked in reverse(up is down and vice versa).
If anyone knows I could really use the help. Thank you. JTS
