Sealing O2 Sensor Opening
Old Feb 25, 2005 | 03:12 PM
MYCoupe's Avatar
MYCoupe
Default Sealing O2 Sensor Opening
I'm installing a Corsa exhaust that was designed for a '96 so it has the extra O2 bung welded on which obviously I don't need for my '94. Anybody know if a pipe plug will bolt into the O2 opening? I don't have an old sensor around so that is not an option and I don't want to have the opening welded shut. Appreciate any feedback on this.
Old Feb 25, 2005 | 03:28 PM
redbullapril23's Avatar
redbullapril23
the easiest thing would be to get an 02 bung from a store.. take it to ace hard wear and find somthing that will fit it then return 02 bung.
I have 2 extra rear 02 sensors if you need them...
Ill send them to you for shipping if it helps you out!
let me know.
also you could have something welded over it.
your friend
Sean
Old Feb 25, 2005 | 03:53 PM
Nathan Plemons's Avatar
Nathan Plemons
You can order an O2 bung with plug from summit for a couple of bucks. That way you don't have to guess on the size. You might also check with a local exhaust shop. They have the TAP for it, they might also have some plugs. My exhaust shop did.
Old Feb 25, 2005 | 05:28 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
plugs for o2 bungs are cheap, check your local parts store
Old Feb 25, 2005 | 05:40 PM
MYCoupe's Avatar
MYCoupe
Thanks guys. I'll take a ride to my local NAPA store tomorrow. Didn't even know they made something like that, figured I'd ask here.
Old Feb 25, 2005 | 05:59 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Get an 18mm x 1.5 replacement oil plug. Fits perfectly. You can also use an old style (large) 18 mm spark plug, same thread pitch. I got the replacement oil plug at Autozone for a couple of bucks.
Old Feb 25, 2005 | 06:49 PM
M.Clough's Avatar
M.Clough
35299 is the walker stock# youcan get them at napa,advanced ,or auto zone
Old Feb 26, 2005 | 10:33 AM
MYCoupe's Avatar
MYCoupe
Thanks again. Got it at my local NAPA store and its a perfect fit. Here's a picture of it for the curious ones:
To Sealing O2 Sensor Opening
