Cam for 406?
It is daily driven, but driven hard with track and road course use.
Comp Cams cc12-450-8 286HR
230/230 .560/.560 110 $244.95
below is info on my setup if you need it
406 retro roller
Head Flow Data
.1 = 67.9 / 56.0 = %82.47
.2 = 134.3 / 113.9 = %84.81
.3 = 201.1 / 167.9 = %83.49
.4 = 248.2 / 206.1 = %83.04
.5 = 276.6 / 227.0 = %82.07
.55 = 282.2 / 233.0 = %82.57
.6 = 283.6 / 239.3 = %84.38
slp cold air
58mm tb
Ported super ram
port matched sr base
ported and upgraded 195 afr heads
3200 vig converter
built 700r4
3.5" alum. ds
(3.73 gears to come very soon)
super comp long tubes
3" y pipe
4" exhaust w/ no cat
holley afpr
cc 1.6 roller rockers
comp cams 853-16 retro fit lifters
hydra-rev kit
march pullies
400 block bored .030"
with TRW forged aluminum pistons TRW-L2489F30
SDPC balancer part
#6272225 also done is
Hot tanked and magnaflux
Bore and hone with deck plate
.010-.010 crank
.035" deck clearance
Resurface deck to flat
cam bearings
checked align bore
Pink rods
Resized rods to bolts
ARP rod bolts
crankshaft oil holes chamfered
complete assembly balanced (externally I assume)
195 74cc
ss 2.020 + .050
ss 1.600 + .050
upgrade spring 8020 to 8015
steel 10 degree retainers
10 degree valve locks
rubber valve seals
guide plates
rocker stud upgrade 3/8 to 7/16 stud
s.b. bronze guides .502
2.200 intake seats
1.695 exhaust seats
helicoils 7/16 14x1.2
angle mill and correct intake 58cc
I think the cam is going to work very well, the 219 is just a bit small in these big inch motors, but 230/230 sounds great. Take a hard look at those gears though, I think they're way too tall for a torque motor that gets some street use and has an A4.
I think you cam will be good for your combo. What is your CR?
Sorry here are all of the Cam specs:
.576/.576 w/ 1.6rr,
280/284 @ .006,
233/233 @ .050
It pulled 9" of vacuum on the 383. This engine hit the 500HP/500TQ level. That cam in a 406 would be more tame but perhaps not enough. It should give you a range though and provide at least an example of how big you can look to go.
Bigger is not always better, I just thought it might help to have a good reference for the top of your range if your still undecided.
With the cam I selected, I will be getting .597 lift. My springs can take a .600 lift. And with the 230 duration on the 406 I should see peak at about 5500 which is a little lower than it could be...but I don't want to be spinning too close to 6000 rpms with the current bottom end configuration I have. If I had better internals that were internally balanced I'd feel better about getting a higher duration and spinning past 6k...which at that point the super ram would become less effective. Considering shifting would be at about 5750, that's about as big as a duration as I can "safely" get by with. I could maybe go with a 233 duration, but it's pushing it in my opinion.
My friend warned me that this cam I selected might not be a small enough base circle to clear all the internals. But I though it would be weird to have a retro fit cam that wouldn't work in a 400 engine? Also they warned to make sure that the lift in the cam wont make the valves smack the piston. Any easy way to check before buying the cam and wasting a head gasket to test?
I think a better cam would be one like their new Extreme Fuel injection HR cams like 230/236 .576 .571lift and 113LSA you can have a retrofit cam customground to the same specs as one of these. Just call them.
PART NO. 08-467-8
01 INTAKE MASTER 3016
02 EXHAUST MASTER 3037
03 ENGINE CS 280XFI HR-13
04 GRIND NUMBER CS 280XFI HR-13
INT EXH
05 HYDRAULIC Y/N YES DurR @.050 230 236
INTAKE EXHAUST 15 LOBE LIFT .3600 .3570
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO 1.60 1.60
07 MAX GROSS VALVE LIFT .576 .571
08 DUR @ .006 TAPPET LIFT 280 288 17 LOBE SEPARATI 113.0
18 ADVANCE 4
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS 26918
@ .006 10 INT 31 69
11 EXH 81 27 DATE SETUP 10/18/2004
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 109.0 INTAKE CENTERLINE
there is one bigger for the brave...242/248 would make over 440hp to the tires on your engine with the right intake, the Super Ram may hurt you power with the head flow you have. I think a well ported SR max flow is in the upper 270cfm range. But it will make gobs or torque...just for your info...
SR with unported Edelbrock base, 52MM - 224 cfm
SR with unported Accel base, 52MM - 233 cfm
SR with heavily massaged E base, mild port runners, 58MM - 256 cfm
SR with heavily massaged A base, mild port runners, 58MM - 259 cfm
SR with heavily massaged A base, massive work throughout - 278 cfm
cam
PART NO. 08-468-8
01 INTAKE MASTER 3018
02 EXHAUST MASTER 3039
03 ENGINE CS 292XFI HR-13
04 GRIND NUMBER CS 292XFI HR-13
INT EXH
05 HYDRAULIC Y/N YES 4 DUR @.050 242 248
INTAKE EXHAUST 15 LOBE LIFT .3650 .3620
07 MAX GROSS VALVE LIFT .584 .579
08 DUR @ .006 TAPPET LIFT 292 300 17 LOBE SEPARATI 113.0
18 ADVANCE 4
@ .006 10 INT 37 75
11 EXH 87 33 DATE SETUP 10/18/2004
